Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 03-08-2014, 02:30 PM
  #10051
K_King's Avatar
Trader Rating: 47 (100%+)
Originally Posted by bigdaddy13
Rear or mid? And are you running all the screws?
Mid. All side pod screws are in. Motor brace screws are not in.
K_King is offline
Old 03-08-2014, 04:19 PM
  #10052
1967rs's Avatar
Trader Rating: 56 (100%+)
Originally Posted by VenturaDC
DE Speedline rims fit awesome as well, plus they come in multiple colors.
+1
1967rs is offline
Old 03-08-2014, 04:20 PM
  #10053
1967rs's Avatar
Mid all screws in
1967rs is offline
Old 03-08-2014, 05:54 PM
  #10054
ThePanda's Avatar
Trader Rating: 68 (100%+)
Originally Posted by 1967rs
+1
Ok, i have heard good things about the de wheels.
ThePanda is offline
Old 03-08-2014, 10:10 PM
  #10055
purple haze's Avatar
well I am about to order this car , which will be my first 2wd buggy , and just have a couple of newb questions . what is a good servo for this type of vehicle ? do I need to get a low profile servo if i am going to run rear motor , with a regular two cell battery from my touring car ? thanks !
purple haze is offline
Old 03-09-2014, 09:56 AM
  #10056
Hey guys I just raced my rb6 for the first time last night and loved won a heat and qualified 2nd. Now I am running rear motor and the rear is locked but has a on power push. I am wondering if mid motor would be better what's everyone's opinion with this car?
Jspires688 is offline
Old 03-09-2014, 11:13 AM
  #10057
cnelson3's Avatar
Trader Rating: 66 (100%+)
From ride height adjusts to just letting off the throttle a bit, an on power push can be from many different things. Mid motor is faster as long as you have "medium" grip or more. I have yet to try mine outdoors at an actual "loose" track but i have the feeling it might be just fine.
cnelson3 is offline
Old 03-09-2014, 01:26 PM
  #10058
I dont think the RB6 will do well at all in a loose outdoor setting. Our track when good is a solid medium grip track, sometimes might push a semi high grip track, but when its dry its miserable to drive, youd have to put so much weight in the back it wouldnt even be worth it. my car drives really well when we have a good water schedule but when we are at the tail end of the heats i might as well pull it off the track, i lose easily a lap and a half.
CaseyD is offline
Old 03-09-2014, 01:41 PM
  #10059
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
You don't need a low profile servo. I am running mine with a full size servo but the receiver is mounted along side the battery. So the layout is like this, Servo, Battery, Speed Control, Motor Brace, Motor.
If you do get a low profile servo you could probably run the receiver behind it instead of on its side. However, I have yet to find a low profile servo that I feel comfortable with its speed and torque output.
Can you post your setup?
Kraig is offline
Old 03-09-2014, 01:56 PM
  #10060
Graham11's Avatar
Trader Rating: 22 (100%+)
Hey guys, have any rb6 owners come from the b4.2/c4.2 platform and can give a short comparison. I currently run c4.2 and deciding between rb6 or b5 and b5m
Graham11 is offline
Old 03-09-2014, 03:39 PM
  #10061
Setup is
Pink springs front red rear
Front camber link 1mm washer inside 1mm outside inside middle hole
Steering reversed with 1 mm washer inside none outside
Rear camber link inside middle with 2mm washer outside outside hole 1mm washer
Ride hieght started out 23f 22r but I raised the rear a few turns throughout the night to help with the push. Hope that's not to confusing
Old 03-09-2014, 03:41 PM
  #10062
I was also able to drive the rear motor b5 back to back with my rb6 last night and I must say the rb6 was way faster through the whoop section and tracked straight way better under power
Old 03-09-2014, 03:52 PM
  #10063
Graham11's Avatar
Was rb6 in rear motor too?
Graham11 is offline
Old 03-09-2014, 04:36 PM
  #10064
Yes both we're rear motor
Old 03-09-2014, 04:40 PM
  #10065
I came from a B4.2 before i got my RB6, the last set up i ran was Maifields set up from CRCRC and it was the best set up i had run to date. I wanted the option of mid motor without having to have two cars so i got the RB6 used already set up in MM. I was shocked at how easy this car is to drive and especially jumping right into MM with a 7.5 motor. i think what shocked me the most is that this car turned better than my B4.2, the RB6 jumps better as well in the MM set up. Ive become so comfortable at MM that i havent even tried the RB6 in RM form.
CaseyD is offline
