TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 03-04-2014, 03:46 AM
  #9571
WIGMAN's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Troubles Dad
lost again, seen people talking about new mid motor setups with the 2.0 parts, any idea on where to find these, I checked the first page and did not see anything posted, so any help please
Here is Casper's MM set-up.
http://www.casper-rc.com/TLR_22SCT.htm
Just click on his set-up to download the PDF
I am currently running Franks 2014 RM set-up on my MM truck and it works great. Only thing I haven't used is the 22 2.0 rear axles. If you race on a high grip track this thing rocks.
WIGMAN is offline
Old 03-04-2014, 03:47 AM
  #9572
WIGMAN's Avatar
Originally Posted by Roken
What are you doing about the steering linkage hitting the shock. I don't want to dremel the lower mount and fight with a shim on the lower shock mount. I'm thinking about shimming out the top mount and then just limiting steering throw a little.
Doesn't seem to be a problem, I have done nothing to my truck to make it work with the 2.0 front end parts.
WIGMAN is offline
Old 03-04-2014, 06:45 AM
  #9573
Trader Rating: 204 (100%+)
thanks for the link, so what did you do with the esc on your truck then
Troubles Dad is offline
Old 03-04-2014, 09:05 AM
  #9574
Casper's Avatar
Trader Rating: 34 (100%+)
Tons of room on the chassis for the ESC and everything else for mm on the SCT.
You can use the 2.0 RM battery hold down system as well which is nice.
Casper is offline
Old 03-04-2014, 09:56 AM
  #9575
Completed my build and love the truck!!! Thank you all for the help, especially Frank for answering my questions.
I need some set-up help. I am running indoor clay track, high grip. Set it up using the Dunford & Casper setup. Only deviation is no sway bars and 27.5 oil in front and rear shocks. Using Panther Rattler tires. Rear end is very loose. Suggestions to modify?
explorerlyon is offline
Old 03-04-2014, 10:00 AM
  #9576
Carranza76's Avatar
Whats the rear ride height?
I was at 25MM with the same set up and I ran no rear sway bar. as soon as I dropped the rear it was locked in.
Carranza76 is offline
Old 03-04-2014, 10:14 AM
  #9577
Ride height was 27mm. Did you drop it to 25mm or start at 25mm and dropped lower?
Old 03-04-2014, 10:16 AM
  #9578
darkstar1974's Avatar
Frank, questionsabout the 2014 RM setup.
what are you using as a spacer b/w the wheel and nut on the 2.0 buggy axles? It's a lot of space you have to eat up. can you take a quick pic of yours?
darkstar1974 is offline
  #9579
Carranza76's Avatar
I dropped to 25 and even went to 23 at some indoor high bite tracks.
Old 03-04-2014, 10:29 AM
  #9580
Casper's Avatar
We like the panther switch 2.0 on the front to take some steering away for indoor clay. For outdoor we typically run a harder tire then the rear (MS fronts and S rears or S fronts and SS rears).
Try playing with the ride height a little as well.
Casper is offline
Old 03-04-2014, 12:36 PM
  #9581
Trader Rating: 22 (100%+)
I used a set of .75 hexs that I wasn't using on my buggy. Just take the screw out so you don't lose it.
Bob Barry is offline
Old 03-04-2014, 08:08 PM
  #9582
I was digging in my spare and extra parts and I think I'm going to try and use the spacers from the old steering rack for wheel nut spacers.
fantomdude is offline
Old 03-04-2014, 09:27 PM
  #9583
Default Old Steering Rack spacers
These work, and are what I use for the spacers.
BuddyLee303 is offline
Old 03-04-2014, 10:18 PM
  #9584
hi all
i am in christchurch new zealand and have just brought a losi 22 but am not happy with how loose on the rear it is, it is all over the place. it jumps very well but that is about all
i am currently running the factory set on a set of aka city blocks.
our track it a outdoor clay track that is very dry,dusty and has not alot of grip. it is also is quite bumpy in parts
i am running it in mid mount with saddles and i am running a 13.5t engine with a little bit of turbo.
would anybody have a setup for mid mount for a medium to low grip track that i am abe to try?
or does anyone have any suggesstions for improvement
i will upload a picture of the track surface next time i am at the track
turtleboy is offline
Old 03-05-2014, 04:39 AM
  #9585
yeah doesn't matter much what you use... just need to take up that space. I saw the Eckerts truck in OH and thought wow... how dumb am I for not thinking of that LOL
