TLR 22SCT Thread (Check First Page for FAQ & INFO)
#8792
Are the stock plastic idler gears strong enough to handle 6.5-8.5 mod motors or are the aluminum versions a must? I'll need 2 if I'm going MM.
For the thrust bearings in a ball diff, can Mobil One grease be used instead of AE black grease? I might take a crack at building a ball diff. I was going to use a gear diff because I suck at building a long lasting ball diff, but it seems like everyone vouches for them.
#8793
Use the B-Fast diff kit.
#8798
Not sure about the Mobil One grease. I use the stock TLR black grease or the BFAST grease. I think the key is proper break in and tightening. Only weak point I have personally encountered is a weak thrust washer from TLR, but, I only use BFAST now and will be trying the ones Casper is offering once my stock runs out.
#8802
Has anyone else ran a Pro 2 in a 2wd SC?
#8804
i would not run mid motor in stock, unless your on carpet or astro....
