TLR 22SCT Thread (Check First Page for FAQ & INFO)
#7981
got my 22sct running this last week. going to run MM. runing on small indoor cement track. major grip, the tire thet works best is the associated rtr tire.
#7982
Suspended
#7985
Did you come up with any setup? I switched to MM with your setup for rear as a basis. I know I have increased the front spring rate. I'm running the smallest front sway bar and no rear at this point. My truck feels really good, was just curious what you were running.
#7987
#7988
Gearing for 9.5T motor?
Looking for a little gearing help. I just got my 22sct and I am putting a viper vtx10 and a viper 9.5t motor in it. Does anyone have any gearing suggestions. I will be running outdoor on clay that usually has a mid bite to it. The track is technical with a lot of turns and jumps.
#7989
TLRacing
#7991
#7992
Suspended
#7993
Gear diff gasket/pad?
Hi guys,
I have a gear dif and want to rebuild it but my gasket/pad is broken.
Anyone knows where i can get this, i can't find it?
#7995
Hey Casper,
I have a quick question about your setup with regard to roll centers. So, for the front, you're using 3mm inner and 0mm outer spacers, so the kit setup. Now, in the back, you have 2mm inner and 2mm outer spacers, which also lowers roll center and increases rear grip over the kit 0/1mm setup. However, if I recall, you're now using 2mm inner and 3mm outer spacers?
If so, that would actually raise roll center and slightly decrease rear grip, no?
The reason I'm asking all this is that I have a ton of steering. So, I was thinking of playing with roll centers in an attempt to even things out. But your raising of the rear outer spacers to 3mm confused me a little, as that would mean you were looking for less rear grip?
