TLR 22SCT Thread (Check First Page for FAQ & INFO)
#5957
Casper I just wanted to up date you!
I set up my truck as stated in the "Casper/Dunford" but was running the stock blue springs had to much "push" today I swapped to the "green" springs and it was a huge improvement! I have did not change the rear A arms like you said I did switch to panther slicks and it seams to have stopped the truck from spinning out and tracking it better too
truck is getting there its the best its been, I would like a touch more turn in while on light power achieved? Some parts of the track it had so much grip its flipping over would lowering the right height help or cause other issues its currently at 28mm?
Thank you for all the help!
#5958
#5959
Hey I have a weird tech question. I snapped a wheel spindle the other day on my 22t. I have a 22sct too. I went to my spares kit and only had sct spindles so I went to change both. Found out that the T has a longer spacer between the 2 bearings than the sct and buggy.My question is can I run a sct/buggy spindle on my T using the correct spacers axle and wheel hex from the sct without affecting my geometry (I understand buggy is 2mm trailing and sct is 4mm trailing vs the T at inline) I just want to cut down on my spares kit of you know what I mean. That and try the difftent effects of the levels of trailing
#5960
The shock are as stated above, I missed the ride height setting I'll drop it down see how that go's
#5961
"I would like a touch more turn in while on light power achieved? " I don't understand this? You want more steering into a corner while still on power? Most of the time we are off power going into a corner and then pick it up on exit. Is this for high speed sweepers or a little more help understanding what you are trying to achieve?
#5962
casper i have been battling the same exact issue to a T with this setup. I am running a full pack all the way back with 14g then 21g over the transmission and still the same result. even if the rear sway bar is a white sway bar, would disconnecting the rear help that much?
#5963
#5964
You can try moving the front shock location to the inside hole on the arm. This typically produces a lot more turn in. If that is too much try it with the blue front springs. You can add a touch more front camber or take a 1mm out from under the front camber ball stud. All things I would try.
#5967
Here's a tuning question for everyone. How do you make the determination if you've got too much steering?
Yesterday i was having trouble with oversteer around a sweeper and a tight 180 uphill. I diagnosed it as I was loose in the rear but in retrospect, I think I should have changed out my front tires for something with a little less grip - harder compound or different tread.
#5968
#5969
[QUOTE=Casper;11803674]Black grease is a bad idea behind the main ring. Silicone is the only thing to use for the main gears as there has to be a level of friction required for those to drive. If you have a grease that reduces friction too much the drive rings will slip and you can't get the diff to set. ONLY clear grease around the main balls and rings. The thrust bearing you can use black grease or other similar hi pressure grease.
Thanks everyone for the input. Black grease between the diff rings and outdrives is somthing that I believe is in the ft sc10 instructions. I understand this is not an sc10 just a build habit I carried over to the 22 platform. It makes total sense why the rings would slip on the outdrive. Never did on the ae though. Will rebuild and assemble minus black grease.
#5970
I would say it was at the apex or just into the exit and easy to correct with steering input - though on the sweeper the speed was high so reaction time had to be on point.
