TLR 22SCT Thread (Check First Page for FAQ & INFO) >
Like Tree1Likes
Old 11-24-2012, 10:19 PM
  #4471
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by jnyrcr
Thank you, I wasn't sure, to many cars over the years I guess.
Yes 22 are all 2.43.
XXX black tranny was also 2.43
XXX gray tranny was 2.56
XX buggy tranny was 2.43
XX truck tranny was 2.61
Casper is offline
Old 11-24-2012, 10:32 PM
  #4472
RShockley's Avatar
[QUOTE=Damian VanRiper;11477520]
Originally Posted by Whitey_Wangster
Hey guys,
Looking for a for a rough loose low traction set up for outdoors. The first page really doesn't have a good set up. Thank
Try this, very basic basic setup,
REAR: 27.5 weight, pink spring
FRONT: Blue spring, 30.0 weight
Pretty much stock everything else
Run 30wt with 2 hole 1.6 pistons. Instead of gluing and drilling just get the associated big bore pistons. black front springs with yellow buggy rears. 4 degree LRC toe block. 4 degrees anti-squat. 3oz weight replacing rear battery pad. battery position: 1 pad front / battery / 2 pads / 3oz weight 1/E rear camber link with 2mm shims on the outside and no shims inside. -1 degree camber.
I have found this to really lock in the rear and then you can just start adding in steering as needed for your track.
RShockley is offline
Old 11-25-2012, 07:07 AM
  #4473
tony montana's Avatar
Trader Rating: 76 (100%+)
most of you guys running full size lipo's or shorty's for indoor medium traction tracks?
tony montana is offline
Old 11-25-2012, 07:49 AM
  #4474
Trader Rating: 36 (100%+)
I run both. I change depending on traction for the most part. I'd like to try the Orion WTS battery.
thefatkid is offline
Old 11-25-2012, 10:00 AM
  #4475
Thanks guys,
Damian on your set up are you running 55 pistons all the way around. Thanks
Whitey_Wangster is offline
Old 11-25-2012, 10:11 AM
  #4476
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
I tried a shorty pack this weekend and could not believe the way it felt in the truck. I ran it in the center of the bat tray and the truck just felt so responsive and it felt like it had more forward punch.
I forgot to check my ride hight though with the shorty pack.
Decided to order one since I was borrowing one from a buddy since it is a good option to have.
kjohnsiii is offline
Old 11-25-2012, 03:36 PM
  #4477
Grandturk's Avatar
Well... My diff went today. Havent taken it apart yet. Loosened in the third qualifier. I tightened it a ton but it only held on for 11 laps in the main then came loose again. bummer
Grandturk is offline
Old 11-25-2012, 03:55 PM
  #4478
Cloaked's Avatar
Trader Rating: 15 (100%+)
I have noticed by ball Diff on my 22SCT becomes a lot looser then my 22 Buggy.
Cloaked is offline
Old 11-25-2012, 04:19 PM
  #4479
Grandturk's Avatar
I'm guessing the thrust bearing is shot and the diff screw is backing out. Hopefully it just just needs a rebuild.
Old 11-25-2012, 04:59 PM
  #4480
Cloaked's Avatar
Time to try out that associated Diff Kit I just bought
Cloaked is offline
Old 11-25-2012, 05:00 PM
  #4481
I got tired of worrying about ball diffs. I put in a gear diff, filled about 1/2 way with black grease. Now I don't have to worry about it. Feels the same to me, maybe better! I recommend keeping a couple extra idler gears though...
nitroburnt is offline
Old 11-25-2012, 05:03 PM
  #4482
Grandturk's Avatar
How have your lap times compared?
I was also Thinking about getting a gear diff to try. Seems some other brand guys swear by them.
Old 11-25-2012, 05:06 PM
  #4483
Cloaked's Avatar
Its funny, 2 other guys at my track put Gear Diffs in there 22SCTs.
Another guy put an Associated Gear diff in his Rango DESC210
And 2 good mates just put Rango Gear Diffs in there DEX210's....
Im seeing a theme here hahaha.
Now the question is do I try and Jam an Associated Gear Diff in the 22 or just get the Losi 22 gear diff...
Cloaked is offline
Old 11-25-2012, 05:16 PM
  #4484
AndrewTom's Avatar
Uhhhh, id go with the losi in this case!
interesting, I guess this thing has so much steering that a gear diff doesn't hugely affect it. cool.
AndrewTom is offline
Old 11-25-2012, 05:34 PM
  #4485
First weekend with gear diff I had the fastest lap of the night (including buggy). I used a Losi gear diff. Not sure if the Assoc would fit. I have always liked Assoc ball diffs. They are much less finicky. Build with the good parts, tighten, back off 1/8 turn, run for about a month. Got a 22 last winter. Ball diff really needs rebuilt every week or two. -Not knocking Losi, I sold all my Assoc stuff and am now running the 22sct -loving it! It does everything very well! I am curious what Associated's next generation of buggy will be like. They've had a year to check out the Losi and Durango... (sorry, off topic) -back to the 22sct -did I mention I'm liking it?
