TLR 22SCT Thread (Check First Page for FAQ & INFO)
#4444
What sway bars are you guys starting off with? I'm still basically running the kit set-up so far. I've dropped down to 3* caster and like the low speed steering. Will adding sway bars take away steering? The current layout at our track has some tight 180's and I think sways will make the truck feel not as lazy. Thanks
#4446
@Cloaked: That's impressive! Nice job!
Swapped kit caster to 25/5 and was very impressed with the steering response tonight. Turned on a dime and really rotated through the tight S sections. Going to add soe sway bars o see if I can carry more speed in the sweepers.
#4447
Same thing happened to me, only I've got the aluminum hubs, but it did wear away some of the aluminum. Put a little locktite on the pin, then lock down the pin with the set-screw and make sure you add a little locktite to the set-screw as well. Once I did this, it hasn't happened since.
#4448
I'm only running them on my Steering links, the rest haven't given me any problems. If they for some reason start, then I'd have no qualms about using them throughout the truck. But honestly, the only place that needs it is the steering links.
Ill run it till it breaks, got another set of plastics on order... somehow Amain were out of the pins though
PS. Thanks for the Tips, Blue locktite on everything
#4452
It gets even more impressive, once I took it apart it had shredded through the whole circle. Its obviously happened when I was at full throttle.
#4453
I had two big Blue Groove races before the Sway bar kits came out so I just built my own. Simple to do on the front, just get the XXX-SCT Rear kit and the SCTE sway bar kit. Use the Bars from the XXX and the mounts from the SCTE. For the Chassis all I did was take a 3MM screws with a aluminum washers and it work perfectly. If you need it in a pinch it works great.
