TLR 22SCT Thread (Check First Page for FAQ & INFO)
#4486
First weekend with gear diff I had the fastest lap of the night (including buggy). I used a Losi gear diff. Not sure if the Assoc would fit. I have always liked Assoc ball diffs. They are much less finicky. Build with the good parts, tighten, back off 1/8 turn, run for about a month. Got a 22 last winter. Ball diff really needs rebuilt every week or two. -Not knocking Losi, I sold all my Assoc stuff and am now running the 22sct -loving it! It does everything very well! I am curious what Associated's next generation of buggy will be like. They've had a year to check out the Losi and Durango... (sorry, off topic) -back to the 22sct -did I mention I'm liking it?
#4487
Track conditions?
What oil?
Might go to a gear dif too
#4488
Im curious to know as well.
From what I can read, the Lower Viscosity Oils are good for your really loose or low traction conditions. They provide more grip but less "On" power stability.
Where are the High Viscosity oils provide less grip but more on power stability. So better suited to High Traction conditions.
However given that 2WD's tend to be very tail happy, Im thinking maybe 5K for my loose condition track.
#4489
Well, here's my exploded thrust washer.
The outermost washer disintegrated. The inner one was still OK. This is the first I've had the diff apart since I built it when te truck was released and ran it 1-2 times per week since. The diff itself was in very good condition - smooth and clean on the inside.
#4490
The track I've been running on lately is a pretty tight, med /high traction, hard packed dirt. Lots of 180s, some banked, and a high speed 90*. Not perfectly smooth. If not watered frequently, get dusty pretty quickly. So -pretty wide variety on conditions.
Truck Holeshots GREAT. I like a consistant feeling, bulletproof diff, so I can lay down the power when needed. Now, if we can fix the idlers...
Hope this helps. BTW, I havn't met anyone yet that switched back to the ball diff. And I certainly can't drive well enough to tell the ...diff?
#4491
Well the Viper Powered Mid Motor Setup 22SCT worked out real good on Friday Night!!! Ran it is the Stock 17.5 Class. Usaully has the best turnout @ the track and the top racers. 16 cars showed up only 6 go to the main. I missed the main by 3 seconds. I usually tail the B-Main after qualifying. I basically threw the truck on the track. I just had got there cause of work. "CARPET OFF-ROAD" So the warm-up lap was my practice. The track is dominated by Associated, Traxxas, and Kyosho. The Kyosho driver is a Team Driver. It is me and one other Losi. Our Triple X's were getting spanked. I will tune and run one more time then I will post my setup. Also gonna be running it on a high bite clay track soon also.
#4492
R/C Tech Elite Member
#4493
does anyone know about this diff and slipper video, mentioned by alex @ 7.25 in ths video.
http://www.youtube.com/watch?feature...v=XLpiIH4RcuU#!
i did find the video myself. here it is if your intrested.
http://www.youtube.com/watch?v=EToj2...feature=relmfu
#4494
i just got my 22sct put together. im going to be running a tekin rs with a tekin redline 8.5 first gen one. what is a good gearing setup for this setup on a larger outdoor track. i was thinking 18/86.
#4496
Hey guys what would be the best starting setup for a high bite small indoor carpet track. Will be running 17.5 blinky. Thanks.
#4497
Tech Legend
Trader Rating: 51 (100%+)
2nd race on my new 22SCT and all I can say is wow this thing is crazy. I have so much traction I can traction roll on the end of the straights. Only changes from last time I ran was rear sway bar and went to D camber link position on the rear hub. Still need the front sway bar yet to complete my setup along with the rear brass weight but it was still another .13 faster than last time I ran and about 5 seconds faster overall. Truck is awesome.
#4498
#4499
Setup!!!
I'm running a Viper VTX10 w/ a 17.5 on a small high bite carpet track in Pa!!! LOL!!! I think the other side of the state tho. I started with 24/76 in mid motor. Ended up ending with 22/76... The truck could really take the sharp turns with the mid-motor setup. I was cutting inside of alot of trucks in my Qualifiers and Main. I have my full setup I can send to you!
#4500
