TLR 22SCT Thread (Check First Page for FAQ & INFO)
#3812
#3814
#3816
latest change that really helped:
moved my rear shocks all the way in on shock tower, and added 7g of weight over tranny. the truck was a lot more planted, and I could feel the decrease in wheelspin coming out of corners. I was able to drop from 23.1 lap times to 22.5 lap times @ OC/RC(though they weren't all 22.5's the truck did show a vast improvement)
#3820
all right, have a bad off power over steer issue going on. Mid motor set p lots of weight added. all 70 grams of mid motor weight kit and aluminum bulkheads front and rear and alam front pivot.
Front:
-1 toe
RH 30mm
-1.5 Camber
Caster/Kick 0/30
Oil 32 1/2
piston 57
spring black
3mm internal limiters
shock location 3-outside
0mm bump steer
camber 1 1mm outside 2mm inside
spindle 2mm above casterblock 0 below
Rear:
loose ball diff
toe -3.5
antsquat 2 deg
lrc
RH 30mm
camber -1.5
Hub all the way forward
+.75 hex
30 Wt oil
55 piston
yellow spring
3mm internal spacer
location 2 - outside
Battery 1 middle
Camber 1-b 1mm outside 2mm inside
4000mah shorty (dont have any other packs)
Any sugestions. The front end just seems to carve hard on and off power, but off power its really bad. the back end just wants to in the front
Hard pack LARGE 1/8 track ran dry and dusty. using hole shots or blockades
Please help race starts early sunday morning
Front:
-1 toe
RH 30mm
-1.5 Camber
Caster/Kick 0/30
Oil 32 1/2
piston 57
spring black
0mm bump steer
Rear:
loose ball diff
toe -3.5
antsquat 2 deg
lrc
RH 30mm
camber -1.5
+.75 hex
30 Wt oil
55 piston
yellow spring
3mm internal spacer
Battery 1 middle
#3822
Mine stock is 12.5 there is 2 models.
TEP1082M. 3700kv 12.3 rotor
TEP1082. 3500kv 12.5 rotor
I just ordered the 1082M after much deliberation between stock motors. Hoping to run this winter indoors at RCExcitement.
Paul
#3824
1082 comes with red rpm rotor. Good for blinky buggy.
#3825
Front:
-1 toe
RH 30mm
-1.5 Camber
Caster/Kick 0/30
Oil 32 1/2
piston 57
spring black
0mm bump steer
Rear:
loose ball diff
toe -3.5
antsquat 2 deg
lrc
RH 30mm
camber -1.5
+.75 hex
30 Wt oil
55 piston
yellow spring
3mm internal spacer
Battery 1 middle
Front:
-1 toe
RH 30mm
-1.5 Camber
Caster/Kick 0/30
Oil 32 1/2
piston 57
spring black
0mm bump steer
Rear:
loose ball diff
toe -3.5
antsquat 2 deg
lrc
RH 30mm
camber -1.5
+.75 hex
30 Wt oil
55 piston
yellow spring
3mm internal spacer
Battery 1 middle
All the intel has pointed to mid motor setups being best used on high bite surfaces.
Now having just said that,
I just read your post in the 22 buggy thread where you have the buggy mid motor and feeling like it's on rails so I'm guessing you're gonna be the guy that gets your truck dialed as a mid motor too so tell us how that works out for ya.
