SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 01-15-2013 | 12:40 PM
  #2476
ovalracer1m's Avatar
Originally Posted by heavyjeffd
I have the Avid hexes and my tires do not hit the body. Make sure your wheels are the correct offset.
+1, i am running the AE aluminum hexes with hazard +3 offsets and my tires clear just fine. They are close, but clear
ovalracer1m is offline
Old 01-15-2013 | 12:41 PM
  #2477
heavyjeffd's Avatar
Same, I'm running the Avid +3 wheels, no clearance issues.
heavyjeffd is offline
Old 01-15-2013 | 12:42 PM
  #2478
HunterMM's Avatar
have you switched the tires around to see if that made any differance?
HunterMM is offline
Old 01-15-2013 | 12:49 PM
  #2479
Not yet. When I noticed the issue, I did notice one side stuck out further than the other. I will take a picture tonight and mess around with other wheels.
justinco is offline
Old 01-15-2013 | 12:52 PM
  #2480
HunterMM's Avatar
well some wheels are listed as front/rear wheels so that could make a differance
HunterMM is offline
Old 01-15-2013 | 01:00 PM
  #2481
Good point. I did rotate my tires front to back when practicing a couple days ago (when I noticed the rubbing). Pretty sure they are the same wheel though, anyways I'll know better when I have the truck in front of me.
justinco is offline
Old 01-15-2013 | 01:25 PM
  #2482
njnewc's Avatar
Can you guys post pics of your dremel work to get clearance for the Big Bores... Thanks Tim
njnewc is offline
Old 01-15-2013 | 01:45 PM
  #2483
no grinding needed, use the supplied spacers/screws. Mounts and clears fine.
Old 01-15-2013 | 01:46 PM
  #2484
Is your body centered on your mounts? Sounds like a miss-centered body and making the body rub on one tire and not the other. That or deformed body mounts. It will not take much with hexes and +3 offset wheels.
Old 01-15-2013 | 03:46 PM
  #2485
mxracer458's Avatar
no dremel work needed unless you add the 4th whole.here is my bbs on my truck,i actually use the smaller black washer up top. 1st picture is the fronts.
Attached Thumbnails SC10 Thread Part 2-photo-1.jpg   SC10 Thread Part 2-photo-2.jpg   SC10 Thread Part 2-photo-3.jpg   SC10 Thread Part 2-photo-4.jpg
mxracer458 is offline
Old 01-15-2013 | 08:15 PM
  #2486
HunterMM's Avatar
needing ideas about tires for my sc10 2wd... no serious racing just wanting some traction on a dirt track.. any ideas would be nice!
Thanks!
HunterMM is offline
Old 01-15-2013 | 08:34 PM
  #2487
HB beams seem to be the hot tire at the track I go to. Clay surface.
JJay03 is offline
Old 01-16-2013 | 05:05 AM
  #2488
bds81175's Avatar
Moderator
It depends on the track surface. If its pretty loose and gnarly you could try a Proline Caliber or AKA Enduro. The Caliber isn't exactly a great race tire but it does do well in loose, rough conditions. Both of those tires would work pretty well for bashing as well. I actually run super soft Enduros on the front during the summer months at the high bite outdoor clay track. Snipers and Tazers work on a green clay track as do Pressure Points. Once the clay starts to pack and a good groove forms a lot of people gravitate towards a bar tire like a BarCode. However, as ovalracer1m will tell you, the Panther Rattler kicks the snot out of the Barcodes on our local indoor clay track. Compound makes a huge difference too. Talk to the locals about what they are running. Hope this is helpful.
bds81175 is offline
Old 01-16-2013 | 07:58 AM
  #2489
Do I need to run the ballstud foam covers? I usually run on outdoor 1/8 size tracks. Wanted to know if it is worth replacing the damaged ones.
Cheers.
Dehydrated is offline
Old 01-16-2013 | 08:06 AM
  #2490
Wildcat1971's Avatar
Need? No you dont need to. They are suppose to keep debris out of the cup. They "maybe" help the cups and balls last longer. But otherwise serve no real purpose.
Wildcat1971 is offline
