SC10 Thread Part 2
#976
#981
Hey guys I have a slight traction prob going on here, the prob is only in two places on the track one in the apex of a big sweeper and at a 160 deg sharp turrn my back enjd washes a tad I can catch it mkost of the time and the only fix I have had working is not going so fast in those spots but I know there ia something I can do wit setup to fix this issue. I'm running
Chad due setup with some tweeks
35 wt oil ft
3 piston
31 ride height
Losi bb green
Less aggressive tire up front
Rear is
30 wt oil and 1 piston
29 ride height
Losi white
.5 deg hubs
Gold barcodes
Help please
35 wt oil ft
3 piston
31 ride height
Losi bb green
Rear is
29 ride height
Losi white
.5 deg hubs
Gold barcodes
Help please
#982
35 wt oil ft
3 piston
31 ride height
Losi bb green
Rear is
29 ride height
Losi white
.5 deg hubs
Gold barcodes
Help please
35 wt oil ft
3 piston
31 ride height
Losi bb green
Rear is
29 ride height
Losi white
.5 deg hubs
Gold barcodes
Help please
#984
#990
ok, I was using the search function, had to state that, but i didnt see "how" to drill the 4th hole. Can I user an old tower and offset it and bolt it on then drill the hole using the old tower as a template? Also, most o the setups seem to be for med to high bite, I run on low to medium. is the 4th hole even required? Same with C hubs. I run A hubs on my b4 and they work well on my local track. So would I stick with A on the truck? I am not a fan of the shaved brace, they brake non stop. I know strc makes an alum one.
Maifields setup from last years nationals looks like it might be a winner for my local outdoor track. His tire choice confuses me though.
http://www.teamassociated.com/pdf/ca...rnats_2010.pdf
24Likes
