SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 09-05-2012 | 12:47 PM
  #1006
Wildcat1971's Avatar
Originally Posted by Matt Trimmings
I use the ae lead weights.
yeah matt, AE switched to iron. Says FE on the weights. tower listed this exact same part number as lead, so i am confused. I assume AE updated from lead to iron
http://www.amainhobbies.com/product_...is-Weights-2oz
I will try to swing by harbor freight this weekend and try out their iron weights. since need to weight down my sc10 and my 4x4
Wildcat1971 is offline
Old 09-05-2012 | 12:50 PM
  #1007
Matt Trimmings's Avatar
Hmm... Those are the ones I use then.
Matt Trimmings is offline
Old 09-05-2012 | 01:05 PM
  #1008
TimMo846's Avatar
Originally Posted by K4
Do you guys know what size of drill bit to make the 4th hole in the shock tower?
I'd suggest putting a bit in the existing holes and seeing which would be the closest fit to them. But the 3/32 should be close, I can't remember which I did mine off hand.
TimMo846 is offline
Old 09-05-2012 | 01:36 PM
  #1009
gamedog1966's Avatar
Talk8ing ab out the 3 oz in the batt tray, will the truck feel diff from one another if I stack 3 oz and place them behind the batt foam or if I just cutout a section in the batt foam and place them there linearly?
gamedog1966 is offline
Old 09-05-2012 | 02:39 PM
  #1010
Maifields setup does not say it, but is the ballast weight used on the sc10 behind the tower? I have put 1oz behind there on my b4 and it fit nicely. or is that too far back?
Old 09-05-2012 | 04:26 PM
  #1011
RC_nooberton's Avatar
My weight is mounted to the chassis and then I hollow out the sc10 battery foam a little and place that over it
Matt, sorry if I missed it but how much weight are you putting under the battery foam? Are you running the battery all the way back?
Thanks for the continued education
RC_nooberton is offline
Old 09-05-2012 | 04:53 PM
  #1012
I run the 3oz in the back of the battery compartment, also running a shorty pack and an additional 20g in the battery compartment. I'm also using the ballast weight.
Old 09-05-2012 | 04:54 PM
  #1013
Would an aluminum front bulkhead so anything for steering or other thing that's positive? Or would it just empty my bank account faster? lol
shagnat is offline
Old 09-05-2012 | 05:46 PM
  #1014
lol, looks like a tank. I think I will try 1oz behind the tower also, I need the rear to be planted.
Old 09-05-2012 | 05:50 PM
  #1015
Actually not too bad, especially with the shorty pack.
Old 09-05-2012 | 05:57 PM
  #1016
SAMCRO's Avatar
Has anyone had any luck running the 20 or 25 degree front caster blocks?
SAMCRO is offline
Old 09-05-2012 | 06:23 PM
  #1017
yeah, the guy that won 17.5 nars, lol. he ran 25's in his sct
Old 09-05-2012 | 08:50 PM
  #1018
J_Bone's Avatar
What motor size are you running?
J_Bone is offline
Old 09-06-2012 | 06:25 AM
  #1019
17.5-13.5 depending on where im running, I have been taking some of the weight out for higher bite tracks and it's worked well.
Old 09-06-2012 | 06:39 AM
  #1020
Matt, have you ever run RPM front arms on the sc10? Are they softer/stiffer than the AE plastic ones?
