SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 01-14-2013 | 08:55 PM
  #2461
heavyjeffd's Avatar
Originally Posted by FORT-26
Speaking of these trucks handling like land yachts and having large clunky bodies....
What are some of the best ways to quite the body rattle besides foam washers stuck on the body? Any neat tricks out there?...
I velcro the sides of the body to the nerf bars.
heavyjeffd is offline
  #2462
Wildcat1971's Avatar
+1 converted mine to a t4. Chassis + body mounts ftw. cheap conversion. Already had the body and tires, lol;.
Wildcat1971 is offline
Old 01-14-2013 | 09:05 PM
  #2463
FORT-26's Avatar
Looking for velcro now...that should do it...
FORT-26 is offline
Old 01-14-2013 | 09:07 PM
  #2464
Not sure. I did the foam washers but noticed more of a problem when I upgraded to FT aluminum clamping rear hexes. The FT hexes seem to be a bit bigger than the stock plastic ones so now my rear wheels stick out past the fender well on the body. Anytime my truck squats (for a jump) or lands my body is banging on the tires
justinco is offline
Old 01-14-2013 | 09:08 PM
  #2465
Oh good idea!
justinco is offline
Old 01-15-2013 | 11:42 AM
  #2466
I am new to 2wd 1/10 coming from nitro. Got an FT sc10 and will be running a revtech 17.5 with MMP. Can you guys list some of setups who run this motor to get the most out of it. Running on a small tight track with hard packed dusty top dirt. I have an 81t, 84T, and 75T spur now with 21, 23, 25 pinions. Looking for what gearing, timing, etc you guys run. Thanks.
bigbeej is offline
Old 01-15-2013 | 11:52 AM
  #2467
HunterMM's Avatar
well just joined this site so still unsure how it works...
anyway im looking to buy some tires for my sc10 2wd... im not looking to do any serious racing just mainly being able to get some traction on a dirt track...
ive looked at jconcepts double dees and subcultures and im just not sure what tire to get..
any help or ideas would be nice!
thanks
HunterMM is offline
Old 01-15-2013 | 11:54 AM
  #2468
I kinda like the Proline Blockades for generic track tire. But you proably want to ask the guys at the track.
Old 01-15-2013 | 12:03 PM
  #2469
HunterMM's Avatar
yea i plan on asking some people next time i go to my local hobby shop
HunterMM is offline
Old 01-15-2013 | 12:11 PM
  #2470
People with FT trucks or FT rear aluminum hexes; does your truck body hit the rear tires at the fender wells when suspension compresses? I'm not talking about on the inside flat part, but the tires stick out past the body now, and the vertical piece of the fender well hits the tires.
I recently upgraded my RTR SC10 to FT rear aluminum hubs and aluminum clamping hexes. Since adding the hexes I have a noticeably wider rear wheel base, the stock plastic hexes don't make the wheels stick out past the body.
Should I just trim up the wheel well so the tire doesn't hit?
justinco is offline
Old 01-15-2013 | 12:13 PM
  #2471
My friend has the same issue with the avid hexes. Do the stock plastic ones strip out that easy?
JJay03 is offline
Old 01-15-2013 | 12:15 PM
  #2472
Mine didn't strip, they worked fine. I just wanted the clamping hexes so I could leave them on the axle instead of them always sticking inside my wheels. I did have issues with stripping axle pins (stock ones) with the stock hexes, so I also got solid pins with the aluminum hexes to eliminate that problem.
justinco is offline
Old 01-15-2013 | 12:17 PM
  #2473
HunterMM's Avatar
are you using adapters for your sc10 or just regular hex hubs?
HunterMM is offline
Old 01-15-2013 | 12:25 PM
  #2474
heavyjeffd's Avatar
I have the Avid hexes and my tires do not hit the body. Make sure your wheels are the correct offset.
Old 01-15-2013 | 12:29 PM
  #2475
I am using these guys:
http://www.amainhobbies.com/product_...Hex-Set-Blue-2
That was my other thought. I think I have the Proline +3mm hex wheels, maybe that is it? I'll put my stock wheels on tonight and see what they look like.
justinco is offline
