-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   SC10 Thread Part 2 (https://www.rctech.net/forum/electric-off-road/632899-sc10-thread-part-2-a.html)
Numburn 11-27-2012 11:05 AM
I would highly recommend setting it to 100% on your ESC, then adjust it using the remote. As said, it's a tuning option so being able to set it on the fly with your remote is nice.
RC_nooberton 11-27-2012 12:23 PM
^ I like this idea.
Sviglienzone4 11-27-2012 12:35 PM
I dont think my remote can adjust the brake. I have the Futaba 3PL. Will soon upgrade to the MT-4 i think.
Numburn 11-27-2012 12:40 PM
The 3PK and 4PK have something called "ATL". I'm not sure what that stands for, but is your brake percentage. I have it bound to one of the wheels on the grip, which is probably how it comes. That way I can adjust real quick and easy.
I'm not sure if the 3PL has that option, but there's more than one way to skin a cat. Calibrate your ESC at 100% throttle and brake EPA, then simply turn down the brake EPA to whatever you want.
mxracer458 11-28-2012 04:02 AM
Anyone run a rear swaybar? I run on some med to high bite and just wanted some opinions
shagnat 11-28-2012 04:58 AM
Great question. I'd like to know also.
getloose 11-28-2012 08:42 AM
I run one and it helped a lot on a high bite clay track. tamed down the rear body roll that was scrubbing off speed.
Wildcat1971 11-28-2012 08:44 AM
the new JC axles are out. so it you are breaking the AE ones, try the jc ones, they look like a better design over all.
http://www.jconcepts.net/store/index...dex&cPath=5_56
heavyjeffd 11-28-2012 09:09 AM
I have yet to break any of the AE axles (using the Avid hex conversion that uses the RS fronts). :weird:
IRM616 11-28-2012 10:00 AM
Hello. So I run on a high bite track. About 4500 to 6000 sq ft. I'm running 7.5 motor with rs pro. What's a good start...like 84/18???
Sviglienzone4 11-28-2012 02:30 PM
thats awesome that they made those. I currently have 4 spare rs axles so if i break all of them then ill try those.
njnewc 11-28-2012 10:58 PM
I have a rear sway bar in my tool box still in the package.
mxracer458 11-29-2012 03:34 AM
You in so cal? Lol
vfrninja 11-29-2012 05:52 AM
I run mine when the track is tacky, but I disconnect it when the track gets dry. I just take the link off one side.
J_Fitz 11-29-2012 09:29 AM
It's about time!!! My truck was a day away from getting sold because of this issue.
