Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-13-2012 | 06:59 PM
  #1366
kevinpratt823's Avatar
Originally Posted by ChrisAttebery
According to this, if you're using a 340g motor you need a 505g pack to balance the car.
http://www.teknorc.com/2012/07/03/si...cale-electric/
Thank you. I haven't read through everything on the tekno site, but I will now, I didn't realize how in depth they got on there. Without having it on the table with a scale to wiegh each individual tires wieght, it actually doesn't seem feasible to try and calculate it, as the layout and distances from center all determine the distribution of each individual component.
kevinpratt823 is offline
Old 08-13-2012 | 07:46 PM
  #1367
BashemSmashem's Avatar
Stormer charged my card this morning. Waiting for a tracking number now...
Their site shows 4 in stock in case anyone is looking.
I also got my notice from Stormer that it has shipped ! 4 more days ! Gonna be a late night Friday cause once I start an assembly I must see it through till its completed
BashemSmashem is offline
Old 08-14-2012 | 12:21 AM
  #1368
ZERTA RACING's Avatar
Bag O and P...Please check out where I have my transponder mounted only works with the RC4.
Final product
ZERTA RACING is offline
Old 08-14-2012 | 07:00 AM
  #1369
Rob Phillips's Avatar
Anyone ran this after running the DEX408... thoughts/comparisons...
I'm between these two buggies, leaning a bit more towards the EB48
Rob Phillips is offline
Old 08-14-2012 | 07:03 AM
  #1370
Zerta... who makes that parts mat that you have pictured? I like that, especially for builds
Old 08-14-2012 | 07:25 AM
  #1371
HUGHES's Avatar
They're made by Cow RC. Awesome magnetic pit mats, they make any build or maintenance much easier. Check them out at Cowrc.com, thdy have differnt sizes too.
HUGHES is offline
Old 08-14-2012 | 08:00 AM
  #1372
G SquareD's Avatar
Smile Got It!
Talk about getting excited at the office....just my EB48 delivered! Thanks AMAIN!
Was shocked by how small the packaging is.....guessing I'll be even more impressed when I starting building this beauty!
G SquareD is offline
Old 08-14-2012 | 08:14 AM
  #1373
G SquareD's Avatar
Questions??
Nice job ZERTA, thanks for sharing your build pics. Like were you located your transponder.
  #1374
Cain's Avatar
Tech Legend
They have pills for that now you know ...
But, as the vids show (the ones from Tekno that is), its not the size of the packaging, but how you drive it!
Cain is offline
Old 08-14-2012 | 08:45 AM
  #1375
What about using some 90 degree bullet connectors with 2 x 2s packs? Maybe that would allow a different battery orientation.
rcmonkey is offline
Old 08-14-2012 | 08:59 AM
  #1376
PM sent brother. EB48 all the way.
Aaron
Antimullet is offline
Old 08-14-2012 | 10:16 AM
  #1377
I see you went with Traxxas connectors. I was going to do the same, have read that they can handle more amps than Deans. However, my LHS suggested deans. I typically have used deans or bullet connectors.
What are the advantages of going with Traxxas connectors? I would like to try them, as some of my Deans connectors "springs" have lost their tension and they will need to be replaced. Have you not seen this with Traxxas?
I have never had a TRX connector come unplugged on me like I have seen deans do. The TRX have a better connection and are easy to install and plug unplug.
Old 08-14-2012 | 11:05 AM
  #1378
Hey Everyone,
Started the build last night. Finished the diffs and the rear of the car before heading to bed. Just a quick note about something that I encountered when building the diffs:
When you push the outdrive through the diff case/crown gear/spur and then place the o-ring and washer, you may find it difficult if not impossible to push the small pin through the outdrive.
I ran into this with 4 of the 6 outdrives and the simple fix was to spin an Xacto knife blade with moderate force on each side of the hole in the outdrive. This allowed the pin to be freely pushed into those outdrives with tighter tolerances.
I hope this helps anyone who may encounter this same thing.
Thanks,
Kane
Kane-o is offline
Old 08-14-2012 | 11:48 AM
  #1379
G SquareD's Avatar
Got ya thanks. I decided to go with EC5 connectors. They seem to offer the best connection in terms of amp rating. According to the research I did, the only connector that is rated higher in amps is a 6.5mm bullet connector, which I prefer not to have due to the risk of reverse connecting the battery & the risk of having the contacts touch each other, even if they are protected by some type of heat wrap of other insulation.
We'll see it works out, I've never used EC5s.
Also going with high end 12awg for everything. Spoke to Tekin support on the phone and their suggestion is to use 12awg not 10awg, for their RX8/T8 system they had better results with 12awg. Checked the RX8 forum and confirmed that this is Tekin's recommendation.
Old 08-14-2012 | 12:26 PM
  #1380
Aaron
It's nice to share...
Sofa King is offline
