Tekno RC EB48 Thread >
Like Tree2Likes
Old 12-02-2013 | 06:43 AM
  #10066
Originally Posted by one-nil
is the eb48.2 pdf download manual the same as the one in the kit - apart from the motor mount addendum? It just looks so nice all sealed inside the heat sealed bag I loathe to cut it out.
what motor mount addendum? i didnt get any thing like that with my kit...
ebay007 is offline
Old 12-02-2013 | 06:54 AM
  #10067
Well if you've been waiting to pick up a new Tekno kit or parts, today is the only day. AMAINHOBBIES.COM is having their Cyber Monday sale. You'll get 10% off every item by using this code-
http://bit.ly/18HUTu3
steve blair is offline
Old 12-02-2013 | 07:09 AM
  #10068
p23 of the downloaded manual, TKR1445 button head screw + washer was partially screwed into the motor plate before mounting. In the addendum they tell you not to install the button head screw + washer until the motor is ready to be secured to the chassis motor mount.
one-nil is offline
Old 12-02-2013 | 07:22 AM
  #10069
UK.hardcore's Avatar
i just ram it in, the screw catches the mud guard but putting the screw in afterwards really sucks.
UK.hardcore is offline
Old 12-02-2013 | 07:23 AM
  #10070
i built my kit two weeks ego and it was not there...
but it's only because of of the threadlock isn't it? so it won't get dry?
and where can i find a .2 bearing chart?
ebay007 is offline
Old 12-02-2013 | 07:28 AM
  #10071
Mizchief's Avatar
I think all the bearings are the same other than the bigger one used in the updated angled gear box.
Mizchief is offline
Old 12-02-2013 | 07:32 AM
  #10072
Oh, and a setup question,
i run my .2 on a loose dusty bumpy outdoor track, and the stock feels a little loose in the rear and a bit like a monster truck in the sense that it bounces in the bumps.
i moved the rear shock one hole inner on the tower, and the camber link one hole below. i felt an improvement with the shock, but i dont know if i did the right thing with the camber link.
what else can i do the help lock-in the rear? should i go 3K in the rear diff?
and about the bounciness, do i need a heavier oil in the shocks?
the stock oils are about 35 front and 30 rear in AE oils right? so if i go 40 and 35, will it help?
ebay007 is offline
Old 12-02-2013 | 09:08 AM
  #10073
ebay - I'd try 40F and 35 rear to see if that settles it down. To gain more rear bite I'd remove the middle and rear chassis brace and maybe set the front droop to 105.
Mark
munrath is offline
Old 12-02-2013 | 09:29 AM
  #10074
Mark
thanks.
i dont want to risk bending my chassis.
ebay007 is offline
Old 12-02-2013 | 09:56 AM
  #10075
Cain's Avatar
Tech Legend
That could help, as well as going with more rear toe. before I got ahold of the 1.5+ rear hingepin brace, to get the rear end to stick I had to go down to 2K rear diff fluid, and I run lower position on the shock tower for the camber link as well as a short link based on what I was able to gather from Mark Pavadis setup instructions. On the dustbowl conditions here it really helped, enough that I didn't even more the 1.5+ hingepin brace I have sitting here lol.
Cain is offline
Old 12-02-2013 | 10:05 AM
  #10076
thanks.
eBay- understand. If you look at the Tekno website for setups you'll find that most of us don't run them but it depends on the grip level.
munrath is offline
Old 12-02-2013 | 11:30 AM
  #10077
Numburn's Avatar
I'm about to order one of these cars to get back into electric. I have a question regarding batteries. Due to bad luck having 4s packs hold up, I want to go the 2x 2s route. Does anyone have any pics or comments on this setup?
Numburn is offline
Old 12-02-2013 | 11:33 AM
  #10078
Cain's Avatar
Tech Legend
One nice thing I have seen with the new 5mm plug packs is that they have a pass through. I had promatch make me a male to male adapter so You can plug them together and then just run one set of wires without all the funny wire jumping around business, sort of like a saddle pack.
Cain is offline
Old 12-02-2013 | 12:02 PM
  #10079
Numburn's Avatar
Which packs are you running? Do any others have the pass through? I'll have to look for a male/male bullet. Sounds like a real good setup.
Numburn is offline
Old 12-02-2013 | 12:16 PM
  #10080
Cain's Avatar
Tech Legend
right now I am using 7200mah IP lipos from promatch as that is what I use for my Tekno SCT410. I am however looking to buy some dedicated 4S packs in the future.
Promatch also sells 6000mah packs with the same pass thru as well.
Promatch also sells male to male bullets as well.
Cain is offline
