Tekno RC EB48 Thread >
Like Tree2Likes
Old 11-18-2013 | 02:57 PM
  #9901
sn47som1's Avatar
AND aluminum caster blocks.
sn47som1 is offline
Old 11-18-2013 | 03:03 PM
  #9902
Cain's Avatar
Tech Legend
Funny thing is where I have ran the vehicle has range from tight outdoor track to big tracks, loose conditions, like dustbowl loose.
Where in CT are you running this? used to run at Manchester Hobbies when it was open and then Wolcott Hobbies for a bit.
That setup that is on there may:
- Be setup for that particular drivers preferences
- Be setup for conditions you don't run on exactly
Just some thoughts.
Cain is offline
Old 11-18-2013 | 06:37 PM
  #9903
Originally Posted by sn47som1
You are so right brother and your words and definitely wise. But I already received the car all tuned in and dialed toe, camber, oils and I adjusted ride height as needed for the surface. So with that being said, I was still very un impressed and highly doubt that anymore changes could make it night and day. The thing is the set up changes could go on all day, but the car platform and dynamics are what they are no matter what. This is why I wont drive a car that feels like a 10 scale- only on tight indoor track. But I only run on bigger outdoor tracks or street. I highly credit Tekno and they are HUGE for RC and I know the guys on here can offer so much help. Everyone is much appreciated. Without them, my rcing wouldnt exist. I gotta say the truggy looks to be a boat load of fun
I believe the car you have was set up for a looser outdoor track. Running that car on a grippy asphalt track would be a handfull! The true measure of any car is how well it can be adapted for any track. Here , I believe, the Tekno is unbeatable! The chassis and it's inherent dynamics are just a blank canvas. The setup you put on that chassis is the color that makes the whole picture come out! Don't give up so easily.
rcmiket is offline
Old 11-18-2013 | 07:56 PM
  #9904
Based on running your off road race buggy on the street...
Not a good way to judge a vehicle if you ask me.
That would be akin to me complaining that my TC car is too loose in the dirt.
You need to spend a few weekends racing it on the dirt and working on setups the light will come on I guarantee it.
And aluminum parts on the knuckles and hubs IMHO are a crutch for an inferior plastic design. I will take a light unsprung weight part such as the tekno plastic hubs and carriers anytime over more aluminum unsprung weight in my suspension.
Antimullet is offline
Old 11-18-2013 | 08:17 PM
  #9905
Rockthecatbox21's Avatar
A few more pics of the ftw body:
On another note, i do feel after running this car for a whole season, it is a little more nimble than what i would like. I've made quite a few changes from stock and it's a lot more stable, but at times it feels quite aggressive. I really think the main factor is the battery i'm running. It's pretty light @ 436 grams. I'll upgrade to the eb48.2 next season, but i think it might be better due to the heavier smc ~5200's i'll be running. Any thoughts before next year on how to make a car more stable/easier to drive?
Rockthecatbox21 is offline
Old 11-18-2013 | 10:34 PM
  #9906
Genebaby's Avatar
I use the 6500 SMC's now, just a little more weight and a lot more punch.
Genebaby is offline
Old 11-18-2013 | 11:47 PM
  #9907
LAZNICK RC's Avatar
Hi guys
I need some help with building the shocks on eb48.2
Now I have tried all methods suggested on threads and instructions manual and I still can't match my 2 front shocks in terms of rebound amount one shock comes out slowly and a few mm. The other comes out faster and has double the rebound of the other
2) Also on both shocks when I pull out shafts to the max extension they like to pull themselves in a little like the reverse affect of rebound is this normal
Any help and ideas would be great these shock are driving me nuts
LAZNICK RC is offline
Old 11-19-2013 | 03:15 AM
  #9908
Originally Posted by Kane-o
Very happy with the car after our provincial final RC Pro series race. These are a few notes that hopefully some can find helpful:
6) Removing the o-ring under the shock cap eliminated the leaking issue. Additionally I found building the shocks like I do my MP9 shocks provided consistent rebound and no air. I dislike the technique of placing the bladder on the shock body and then shock cap. It reminds me of building TC shocks which I hate! These are the steps I followed:
- Place bladder in shock cap (they will stay put after initial use as they will have expanded slightly).
- Fill shock body nearly to the top and pump up and down.
- Place in shock pump to remove remaining air bubbles (allowing shocks to sit alone will never rid the shock oil of all air bubbles).
- Top off shock oil until flush with top of body.
- Screw on shock cap while shock shaft extended. Do this slowly and stop when oil starts to come out of the bleeder hole.
- Slowly push the shock shaft all the way into the shock body while wiping away oil that leaks out of the bleeder hole with a shop towel.
- While holding the shock shaft all the way in the shock body, slowly screw the shock cap on until it bottoms out (no tools necessary to do this if you remove the o-ring)
- If the above is done correctly you should have close to zero rebound. If you want less rebound only push the shock shaft in the desired amount and hold in place while screwing on the shock cap.
The above steps work well for me and the key is to perform all steps slowly in order to achieve zero rebound. Also making sure the shock is upright while performing the steps is key.
-Kane
This was spot on. Ive have used this method for awhile now. My driving might suck at times, but my shocks are always awesome.
Dont Hack Me is offline
Old 11-19-2013 | 03:32 AM
  #9909
LAZNICK RC's Avatar
Thanks a lot bud will look into this method
Just wondering if end rods where longer more internal thread for shaft to screw into this May prevent nut hitting bladder!
Also what if the bladder had more contact surface were it touches top inside of shock cap to seal better!
What if shock bladder was a little thicker to seal better !
What if shock shafts need to be trimmed a little with how much thread extends above nut were piston is mounted In order to prevent bladder being hit when assembling
A few things I a have been thinking about during my build
Old 11-19-2013 | 05:08 AM
  #9910
snwchris's Avatar
The 4s I'm running is about 385-390grams (13.5oz) and the setup I have posted works great with my light weight 4s. I'm looking at getting a heavier 4s, but the buggy is so nibble with the lighter one in it, especially outdoors I can clear some of the bigger triples and quads easier.
snwchris is offline
Old 11-19-2013 | 10:23 AM
  #9911
Cain's Avatar
Tech Legend
have you tried the new toe in block with more toe added in?
Cain is offline
Old 11-19-2013 | 10:33 AM
  #9912
teknorc's Avatar
That FTW body looks rad!
teknorc is offline
Old 11-19-2013 | 10:45 AM
  #9913
sramos's Avatar
+1 I want one
sramos is offline
Old 11-19-2013 | 10:46 AM
  #9914
I'm actually looking for the direct opposite of what you described. I want my buggy less nimble, and more planted. I'd really like it to drive like my sct410; which is super easy to drive fast.
No, but i will next year with the eb48.2.
Old 11-19-2013 | 11:12 AM
  #9915
Graham11's Avatar
Originally Posted by sramos
+1 I want one
me too, I was hoping it was going to be more like this FTW tekno v4 body but its close. Im not a fan of the JConcepts, I actually love the stock EB48 body, its very distinctive, you know its a Tekno!
Graham11 is offline
