Tekno RC EB48 Thread
#8836
Looks like they are out of stock everywhere.
http://www.teknorc.com/shop/tkr5013b...nodized-1-5mm/
http://www.amainhobbies.com/product_...race-Gun-Metal
#8837
I bought one from here -
http://www.ampdraw.com/product/37729...races-Rear-1.5
Was skeptical as it's out of stock everywhere, but is scheduled to arrive tomorrow.
#8839
#8844
Tech Legend
What is it you are wanting to see exactly?
#8845
Hey guys, I know this question has been asked in this thread but just a quick consensus on everyones preferred 4s Lipo to run in the EB48? I am getting the .2 and want to get a new battery while I am at it. I currently run SMC and very happy just curious if anyone has better bang for the buck suggestions?
#8846
#8847
I CURRENTLY HAVE THE EB48 AND IM LOOKING TO GET THE .2. DOES ANYONE HAVE THIS OR DROVE ONE TO SEE THE DIFFERENCE. THE ONLY THING I DONT LIKE ON THE GEN 1 IS THE LOUD DIFFS.
#8848
Now running ProTek 4S 4300mAh. They are around $130. Just beware I had to solder a Dean's connector on it.
#8849
Charging this pack on my PL8 I see an internal resistance on the cells of .09 to 1.3, this is the lowest I have seen a pack charged on PL8
Gobs of power when needed, 100C discharge
6 min qualifiers I use 45%
8 minutes I use around 60%
Castle MM 100% power, 3.5 volt cutoff, 10 Degrees normal timing, High power start, 100% brake, 0% Drag brake, linear curves.
http://www.amainhobbies.com/product_...k-148V-4300mAh
#8850
can you run the new, updated rear trans housing with old, angle cut diff/pinion gear or if you use the new diff case do you have to run the new straight cut stuff?
