Tekno RC EB48 Thread >
Like Tree2Likes
Old 07-15-2013 | 11:45 AM
  #7906
mmmm camel toe
Mullet1 is offline
Old 07-15-2013 | 12:10 PM
  #7907
protc3's Avatar
I have been running this same car for a year now. Really loving this thing. Not bad shape for a year old right.
Attached Thumbnails Tekno RC EB48 Thread-eb48-1.jpg   Tekno RC EB48 Thread-eb-48-2.jpg
protc3 is offline
Old 07-15-2013 | 12:16 PM
  #7908
Matthew_Armeni's Avatar
I like those blue collars you have on the swaybars, I might have to copy that, if I can find some red or orange ones
Matthew_Armeni is offline
Old 07-15-2013 | 12:19 PM
  #7909
CarlCrocco's Avatar
Yea these cars hold up well, I love how easy it is to clean, 8 screws and the electronics come off in one piece, spray it down and use the air compressor to dry it off.
Brilliant design!!!!
CarlCrocco is offline
Old 07-15-2013 | 12:41 PM
  #7910
Rockthecatbox21's Avatar
When you say "spray it down", do you mean water, simple green,or something else? I've sprayed mine down with water and simple green and the result isn't very astounding. The simple green (half water half simple green solution in a spray bottle) leaves a kind of dull faded look and leaves some residue of the spray behind. The water didn't really clean those tough spots. Either way, i've never got the "showroom new" look all you guys' cars have. What is a good household solution that yields good results?
Rockthecatbox21 is offline
Old 07-15-2013 | 12:53 PM
  #7911
protc3's Avatar
WD-40 and an airhose works great.
protc3 is offline
Old 07-15-2013 | 12:54 PM
  #7912
CarlCrocco's Avatar
I spray it down with the trakpower pink bottle and use a brush to get the gnarly areas. Then I'll take a garden hose and blast the rest off. I use the sidekick to dry it. Then lube the bearings and outdrives with the trakpower dry lube.
This is the sidekick, it's awesome!
http://www.autoanything.com/car-care/69A3936A0A0.aspx
Old 07-15-2013 | 01:01 PM
  #7913
T. Herwig's Avatar
+1
I use Simple Green and water initially with a tooth brush/fine brush, and then a light coating of WD-40 with a compressor after and it looks like new.
T. Herwig is offline
Old 07-15-2013 | 01:02 PM
  #7914
Blown up's Avatar
Originally Posted by bico
When pulling the throttle relatively hard, from close to full throttle to full throttle, the driveline of my car emits a burred and harsh sound. It sounds as if one or more of the three differentials spin and slip to much. Normally the driveline is very smooth and close to silent.
I use a Hobbywing Ezrun WP SC8 120A speed controller and a Leopard 4074 2000kV motor powered by 4S. I use the stock differential oil viscosities: 7k front, 5k center and 3k rear.
I would really appreciate your opinion and look forward to any clues or ideas.
Thanks a lot in advance!
Ever figure out what was causing the noise? I havent had a chance to go thru mine since yesterdays race but mine started making the same type of "deep, vibe noise" on power. I have 7/10/5 diffs but going to try 5/5/3 to see if it helps calm her down in bumpy corners. Everything else is great, It's been either KYO orange F/yellow R or lt.blue F/green R w/40/35 TLR oil and blue CSI pistons.
Blown up is offline
Old 07-15-2013 | 01:15 PM
  #7915
Originally Posted by T. Herwig
+1
Has anyone ever tried Pledge? I know it sounds crazy but when I worked at a bicycle shop in college that's what we used to clean all the filth off bikes for service tuneups. It worked great and then left a super light layer of wax so dirt wouldn't stick to the bike/parts as easily and then when you went to wipe it down it cleaned off easier.
merkyworks is offline
Old 07-15-2013 | 01:19 PM
  #7916
probably the famous bent driveshaft issue. buy the aluminum one
rythby is offline
Old 07-15-2013 | 01:20 PM
  #7917
I use pledge. works great .
rythby is offline
Old 07-15-2013 | 01:21 PM
  #7918
Blown up's Avatar
+1 on the pledge
I'm going to blame this one on the tires...
http://www.rctech.net/forum/attachme...1&d=1373919627
Blown up is offline
Old 07-15-2013 | 01:23 PM
  #7919
Blown up's Avatar
I just added the alum front shaft to my cart
Blown up is offline
Old 07-15-2013 | 01:24 PM
  #7920
anyone try the heavy diff setups?? I kinda like it. 10 - 15 - 7 . I am used to driving a mugen and it handled like a fat lady covered in lead balloons. So running the tekno with light diffs is kinda tough for me. Heavy helped make it easier to drive in my opinion
rythby is offline
