Tekno RC EB48 Thread
#7517
#7518
FYI- New Servo Saver Spring from Tekno RC -- http://www.teknorc.com/shop/tkr5101x...8-sct410-nb48/
#7519
Can you pm me your setup for semi loose conditions. I don't have the niceness of the Cali guys that run on perfectly groomed hard clay tracks.
#7524
That is true. I ran 37.5 front and 30wt. rear and the car was very twitchy. The track is proetty big and pretty rutted. The track doesnt have much flow to it but in areas that it does flow, it is rutted and the car will get squirly in the high speed rutted areas. The The lightest I can get away with is 40 in the front and 35wt in the rear. The stock pistons worked well but had a little too much pack. The 8 hole 1.3 overall worked a little better than the 10 hole 1.1 that came with my car. I dont tune the suspension for the jumps as I always hit the landing jumps. I tune for the rough and high speed sections. The softer springs also help as I can hit the jumps at higher speed. I dont have to pussyfoot as much. The softer springs keep the airtime down.
#7527
#7530
I have mine geared with a 16. My motor is coming off at 180 degrees. Its a little warm but it was also 92 degrees and humid as hell last time out I tried a 17 and the motor came off at 190-200 so I backed down to 16 again. This was also after a 15 minute practice run. Im sure in a 10 minute main I could get it under 180. I tried a 15 but the motor topped out immediatly and did feel slow like you say. It actually felt like a 1900. Once I geared up, it woke up and the temps stayed the same. The 17 actually felt the best but I didnt like the heat.
