Tekno RC EB48 Thread
#5071
Starting the build today. Bag A done. Center diff came with no shims and directions dont show them. Diff feels a little nothchy but nothing as bad as a new losi diff....clunk clunk clunk
Im sure it will wear in fine after few packs change the oil and they are probably good to go. Not sweating it.....yet
#5073
I would never use castle 8th scale stuff in a race setting. It's made for bashing, the power isn't smooth, and it's unsensored. I know some people who race with castle's 8th scale stuff, but it's really not designed for that. You'd be much better off using a tekin, or hobbywing sensored setup. Sensored is the way to go for racing.
if the tekin much smoother and better for racing regardless of the way you control your buggy Matt better to follow what racers advised.
#5074
#5075
The Castle system is fine for racing , sure its not as smooth as a sensored system but if you setup the ESC correctly you can be just as fast with it as a sensored system .
Sensorless ESC software is getting a lot better at being smoother then it used to be , the only thing sensored does better is startup and really low speed running which when racing rarely happens . That said I run sensored systems now but ran Castle systems fo a long time before switching .....
#5079
#5081
first time out with new kit. just a practice day on small track, i love it. turns, jumps, excellerates like a rocket. box stock setup. manual say for more steering try 7 5 2 in diffs. does this give more turn in? on a side note, when i tighten down steering top plate it binds steering.
also can someone tell me what servo horn and where to get? i am in Pa. prefer somewhere besides amain or tekno that is on opposite coast.
lastly not much brakes. i run rx8 and 2050.i have gone thru manual tuning on rx8 but still not what i want, travel is set to 150% last time out on durango dex408 i had to dial brakes out of setup. same motor and rx8.
i had a very high speed abrupt stop with all impact to front today with zero damage. i thought for sure i was going to pick up peices.
thanks for any help to new eb48 owner.
#5082
#5083
If you read back a page or so you'll see a list of horns that work but IMO the hot bodies is the only direct universal replacement.
#5085
Hi friends. If anyone's looking to get into a lightly-used EB48, check the link below.
Apologies in advance to whoever gets mad about me posting this.
http://www.rctech.net/forum/r-c-item...l#post11879290
2Likes
