Tekno RC EB48 Thread >
Like Tree2Likes
Old 10-01-2012 | 02:27 PM
  #2716
Default Shorty lipos
Anyone run Shorty lipos do you run them side by side or on top of each other? Still waiting for part that was missing in my kit . This week I hope
bobseagull is offline
Old 10-01-2012 | 02:31 PM
  #2717
I run them side by side, staggered slightly so the bullet connectors can be inserted into the batteries. I run them all the way forward with foam taking up the rest of the space. So far it has worked well.
MX304 is offline
Old 10-01-2012 | 02:53 PM
  #2718
ChrisAttebery's Avatar
I run mine on top of each other. I tape them together with strapping tape and have the top one staggered forward about 10mm so it will clear the bullet connectors on the bottom pack. I run them all the way forward with a small foam block in front and a larger piece behind the packs.
ChrisAttebery is offline
Old 10-01-2012 | 04:29 PM
  #2719
Here's a picture Pres posted a while back...
Old 10-01-2012 | 04:32 PM
  #2720
I was going to order a couple Ackerman plates today but I can't find one anywhere. I tried Tekno, A Main, Stormer, then searched the web. It looks like they are out of stock everywhere right now. It's a good thing I wasn't planning on racing this weekend.
Old 10-01-2012 | 04:35 PM
  #2721
teknorc's Avatar
We're expecting new stock in a week or so.
teknorc is offline
Old 10-01-2012 | 04:36 PM
  #2722
IIGQ4U's Avatar
Nitrohouse should have it in stock.
IIGQ4U is offline
Old 10-01-2012 | 06:12 PM
  #2723
Danny are you or any other Tekno representatives going to be at the iHobby expo in Cleveland?
sstoffer is offline
Old 10-01-2012 | 06:14 PM
  #2724
teknorc's Avatar
Not this year. Maybe next year, we'll see.
teknorc is offline
Old 10-01-2012 | 06:17 PM
  #2725
Slotmachine's Avatar
I think I`m going to make a spare for my parts box out of graphite this week just in case.
Slotmachine is offline
Old 10-01-2012 | 07:37 PM
  #2726
What is everyone running for ride height? If I put my drive-shafts level I am at about 24mm. I see some set ups at 28/27mm but it seems a little high.
james633 is offline
Old 10-01-2012 | 07:41 PM
  #2727
Thanks! I can't load their site at work, but I ordered a couple as soon as I got home.
Old 10-01-2012 | 08:09 PM
  #2728
SEF's Avatar
SEF
Default servo wiring tip
Maybe this was obvious to everyone except me
Route the servo wire so all you have to do to replace the servo is to remove the 4 screws that fasten the servo to the metal servo plate and the 2 screws that fasten the servo plate to the integrated mud guard. Makes it so much easier to replace servos if you don't have to remove the entire mud guard
SEF is offline
Old 10-01-2012 | 09:51 PM
  #2729
justpoet's Avatar
I wanted to run the cables in a more easily accessible way, but I couldn't figure out a way to do it that I thought kept the cable enough away from drive components, yet neatly held down.
justpoet is offline
Old 10-02-2012 | 03:44 AM
  #2730
protc3's Avatar
The ride height will vary with different tires. Some are taller than others due to pin size and insert. I run the front dog bones a slight bit lower than level and the rear just about level.
protc3 is offline
