Tekno RC EB48 Thread >
Like Tree2Likes
Old 01-08-2013 | 03:02 PM
  #4216
Cain's Avatar
Tech Legend
cool looks like that is what they are configured with along with 7-5-3 diffs and those xray springs.
Cain is offline
Old 01-08-2013 | 07:12 PM
  #4217
Mxer59's Avatar
Just got one of these with low use and the updated parts, I was curious is there anything I should look out for? Also any pieces that break easy? What's a good Esc and batt to run Aswell as pinion prob going to run a Tekin 1900 on 4s?
Mxer59 is offline
Old 01-08-2013 | 08:17 PM
  #4218
superslow's Avatar
Originally Posted by JASF4I
Got my buggy last night in the mail. Worked thru the night and got it built. So far so good. All parts seem high quality. Now need some track time.
Most are using the 2050 I had the 1900 going to thw 2050 with a 16 tooth, just get a set of front arms as a safety precaution nothing really breaks on this buggy!
superslow is offline
Old 01-08-2013 | 08:40 PM
  #4219
Originally Posted by teknorc
Try toeing in about 1/8th turn on each side (yes, it's that sensitive). That should calm down the car on corner entry and give you more mid-exit corner steering.
Glad you found a spring that worked and that you're psyched to be running the buggy again .
Already been there, done that. It helped, but I'm looking for just a little bit less entry steering. I mean a little teeny weeny bit. I am going to try reducing the caster by one degree next time out.
This buggy is as close to perfect as I've ever had any of my cars in over 20 years of racing. That is really saying something
rcmiket is offline
Old 01-08-2013 | 08:46 PM
  #4220
Originally Posted by Slotmachine
Maybe the TEKNO guys can confirm this.............if you limit the front droop some you will gain more on power steering without loosing turn in.
I know you want to loose some turn in though.
You are correct about limiting droop. It will give more steering on power, but taken to extremes, can cause bad jumping behavior, and make the car hard to drive under power.
I am currently at 100mm front, and 118mm rear. I am also running 25mm front and 26mm rear ride height. The current layout has small 10th scale size jumps, and is fast and flowing with many faster turns.
rcmiket is offline
Old 01-08-2013 | 08:55 PM
  #4221
Originally Posted by MacchinaVeloce
Just put in an order for a new EB48, figure the V4 chasis made such a difference in my RC8.2e that i had to try it, that with the less weight, design and having the urge to try something new.
So far i have aluminum servo horn needed part# HBS67168 Ordered
A Tekin RX8 and T8 2050kv, same as my RC8.2e
Packs will be 3700mah 4s
Servo Hitec 7955tg
Anything else thats a must get please let me know, i would appreciate it.
Also a starting set up would be great, especially suspension springs etc... I will put in the Blue CSI pistons so shock oil i will figure out. All I see on the site are sdrc set ups and i run on bigger outdoor tracks. Bigger jumps, rougher in spots, faster straights and turns etc. Still clay hard pack but usually with dust on top till it grooves up. Wet down often with good traction then looser as it dries up as usual. Thunder Ally, Revelations etc.
Thank you all for your help, i appreciate it.
Try this setup to start.
I ran 7-5-3k front to rear for the diffs. 10x1.2 pistons with 35f, 32.5r oils. Yellow front springs, and orange rear. All geometry settings as per Danny's setup on the website except for the shortest wheelbase, and one step longer for the rear camber link.. 2.3r ,.2.4f sway bars. Most importantly, and what made the buggy drive harder out of bumpy corners, was removing the rear chassis brace! I normally don't like to do this, but it makes a huge difference in the bumpy corner exit stability.
rcmiket is offline
Old 01-08-2013 | 10:07 PM
  #4222
teknorc's Avatar
Try some expo on your steering.
teknorc is offline
Old 01-08-2013 | 10:54 PM
  #4223
spunkysandoval's Avatar
^That is what I did to my buggy. Expo is your friend
spunkysandoval is offline
Old 01-09-2013 | 03:47 AM
  #4224
Desert Runner's Avatar
Excuse me guys, what is the expo and what is it used for here ?
Desert Runner is offline
Old 01-09-2013 | 04:36 AM
  #4225
LAZNICK RC's Avatar
Default Eb 48
Hi guys
How are you all finding the eb48!
Any improvements coming up for the kit by tekno!
3rd production run when is that due!
New tekin rx8 when is that due!
LAZNICK RC is offline
Old 01-09-2013 | 04:37 AM
  #4226
Slotmachine's Avatar
I dont think there really is a caster adjustment, but you can change the front kick-up
Slotmachine is offline
Old 01-09-2013 | 04:44 AM
  #4227
Suspended
It's steering exponential. As you add expo it will slow down the steering response accordingly. Say your car feels really responsive to the point when steering some would call it twitchy. Then adding a little expo will take the initial turn of the wheel and turn the wheels less/slower until you surpass the expo setting at which point your steering is back to normal throw/speed. It really helps on corner entry or sharp turns where it's easy to oversteer your car.
MattP is offline
Old 01-09-2013 | 08:08 AM
  #4228
Mxer59's Avatar
For you guys running the rx8 are you guys turning down the current limiter?
Mxer59 is offline
Old 01-09-2013 | 08:37 AM
  #4229
Cain's Avatar
Tech Legend
hmm, on the futaba 4pl i have I found that if I put in negative expo that slowed the steering response?
MXer59: I would suggest giving the steel spur gear a look.
Cain is offline
Old 01-09-2013 | 08:40 AM
  #4230
IIGQ4U's Avatar
^^^ You are correct. Exponential is based on a curve.
IIGQ4U is offline
