Tekno RC EB48 Thread >
Like Tree2Likes
Old 09-17-2012 | 09:24 PM
  #2491
rcgod's Avatar
Originally Posted by ChrisAttebery
Kevin,
The last time I talked to Austin he told me he is only using kit parts in his setup. I have a pretty good setup for NorCal if you'd like it. Kevin and Jesse both liked it when they drove it.
Chris
Chris, please pm me with your setup. Thanks!
rcgod is offline
Old 09-17-2012 | 09:29 PM
  #2492
Exclamation Issue with rear diff pod and hinge pin braces
I have an issue with the rear diff pod and the hinge pin brace. The holes on the rear diff pod are too large to screw the screws into. I have attached a video the explains the problem.
Tekno RC support, please PM me, i can send you a link to a video i shot sowing the problem with my kit.
bob256 is offline
Old 09-17-2012 | 09:33 PM
  #2493
Slotmachine's Avatar
You forgot the video...................
Slotmachine is offline
Old 09-17-2012 | 09:41 PM
  #2494
superslow's Avatar
Hey i just ordered the traktion drive from amain hobbies. i was running a 17tooth pinion i assume i need a 17th clutch bell now? or will gearing be different because of the traction drive for some reason? thank you.
superslow is offline
Old 09-17-2012 | 09:45 PM
  #2495
sorry , i posted it to your public profile, i cant post videos yet on this forum
bob256 is offline
Old 09-17-2012 | 09:56 PM
  #2496
ChrisAttebery's Avatar
I emailed you a pdf setup sheet.
ChrisAttebery is offline
Old 09-17-2012 | 10:05 PM
  #2497
Bob,
You must have the screws swapped front to rear. The rear screws are 40mm(1.5") long. The fronts are only 16mm and won't reach the threads in the front half of the gearbox.
I see you're in Santa Clara, you can buy me a beer for lunch. Where are you going to run it?
Chris
Old 09-17-2012 | 10:20 PM
  #2498
SEF's Avatar
SEF
Originally Posted by wheelman17
42.5 front losi oil
30-32.5 rear losi oil
Stock springs
+1
SEF is offline
Old 09-17-2012 | 10:22 PM
  #2499
Matthew_Armeni's Avatar
17 tooth clutch bell is what you want
Matthew_Armeni is offline
Old 09-17-2012 | 10:29 PM
  #2500
Bob,
Chris
That is right Chris...........I just sent him a P/M with the same answer.
Here is a link to his video..........https://www.dropbox.com/s/tcltoytb1g...917_210110.mp4
Old 09-18-2012 | 12:25 AM
  #2501
delane74's Avatar
Default camber length
using protc3 set up what should the rear camber link be hole to hole. hope his set up helps settle the rear end down. love the car otherwise. reminds me of my tekno d8 before i got it dialed. it will come, thanks for the help guys.
delane74 is offline
Old 09-18-2012 | 01:23 AM
  #2502
IIGQ4U's Avatar
I just finished the build and wiring of my EB48. Tekno RC did a great job with this car. The build quality and fit rivals that of XRAY.
I will throw the car on the setup board tomorrow and I should be ready to roll.
IIGQ4U is offline
Old 09-18-2012 | 03:25 AM
  #2503
protc3's Avatar
I will measure that up when I get home later. As long as you are in the right locations and the camber is set to 1 degree you should be fine. Just be sure that your speedo is set according to track conditions. I see so many cars with traction problems that setup just cant fix. They just have too much motor. I am running an RX-8 with throttle profile 1 and -15 on the expo on the throttle from the radio to curve the power. Between this and the setup, the car was insane.
protc3 is offline
Old 09-18-2012 | 04:46 AM
  #2504
The stock camber locations on the rear are 2-C from there if you want more traction you should make the link longer and higher on the shock tower.
That is one of the most beautiful wireing jobs I have ever seen..........Your Hired to do mine.
Old 09-18-2012 | 05:04 AM
  #2505
kufman's Avatar
Nice wiring job. Did you replace the ESC fan and does it blow upward or downward?
kufman is offline
