Tekno RC EB48 Thread >
Like Tree2Likes
Old 09-03-2012 | 05:21 AM
  #2236
G SquareD's Avatar
Originally Posted by Joe B
No problem, you designed an Awesome car
Hi Joe
What track are you referring to in your EB/811 comparison? Curious where this large outdoor track is? Shiverville or Tallahassee?
I run at Mills Ponds, one of the premier 8th scale tracks in FL and it's good to know where there are other quality 8th scale facilities. Thanks.
G SquareD is offline
Old 09-03-2012 | 05:46 AM
  #2237
protc3's Avatar
Originally Posted by G SquareD
Hi Joe
Joe and I run at B & B Hobbies about 45 minutes north of Tampa.
protc3 is offline
Old 09-03-2012 | 07:16 AM
  #2238
ChrisAttebery's Avatar
You can turn down the current limiter in your ESC. Also check to see if your radio has a traction control function. I use both. I usually set CL to 85%. If I'm still pinning the tires everywhere I keep turning it down until I feel the car is driveable. Then I fine tune the response with my radio.
Originally Posted by toycardriver
I shortened the wheelbase to its shortest setting and it helped a lot, its just the initial on throttle with the wheels turned coming off corner that it wants to jump sideways. It may just be me not being used to electric and waiting on the clutch to engage on my nitro cars.
ChrisAttebery is offline
Old 09-03-2012 | 08:31 AM
  #2239
Pulse_'s Avatar
The first white car is the EB48 from S.Wartelle, this is the A final of yesterday in Meux
http://www.youtube.com/watch?v=rcts-...ature=youtu.be
TQ
best lap
win
You can see my JQ at 3:14, the white/pink/black buggy
Pulse_ is offline
Old 09-03-2012 | 08:41 AM
  #2240
Acill's Avatar
Thats one rough track, but looked like a great time!
Acill is offline
Old 09-03-2012 | 08:54 AM
  #2241
Pulse_'s Avatar
We did 10 hours of endurance on this track in the wet last sunday so it doesn't look as fresh as usualy . But it provides massive grip and tire wear for sure
It definitely was a great time, the EB48 is selling well here as we only have a 1/8 buggy national championship in electric. It should do great in the winter also on astro tracks.
I won't buy one now but might switch for a tekno conversion for my JQ. Once the EB48 will be more mature I will give it a go then.
Pulse_ is offline
Old 09-03-2012 | 12:17 PM
  #2242
Originally Posted by nv529
The 3 servos you've listed are known to break in any 8th scale. They use titanium gear sets which isn't shock resistant like a good quality steel gear servo
If you plan on sticking with savox servos make sure it has harden steel gears the model should be ***SG, for example, I've owned 6 SC-1268SG servos over the last 2-3 years and not one of them has failed.
stay away from the models ending in xxxxTG or xxxxMG
Nick Thanks a lot, I will look into changing this.
cryofix is offline
Old 09-03-2012 | 03:13 PM
  #2243
Working on my build, center diff appears to be rubbing on the top diff plate. Does this mean that perhaps i have the 6 shims wrong? or does something need to be shaved down?
Krafcik is offline
Old 09-03-2012 | 05:29 PM
  #2244
Finally got to run mine today. ran a stock set up, except I took ou t antisquat. track had varying conditions, but was mostly loose. the buggy ran great. much better than my tekno converted d8 can't wait to run it more do tha t my skills can evolve to match the greatness of the buggy.
aggie4231 is offline
Old 09-03-2012 | 06:37 PM
  #2245
Is everyone else having to use a servo wire extension? I'm like 2 miles away from reaching the rx box with the radio post servo
Krafcik is offline
Old 09-03-2012 | 06:42 PM
  #2246
G SquareD's Avatar
Yes Sir....I used the shortest I could find at my LHS....a 4" ext.
Old 09-03-2012 | 06:51 PM
  #2247
protc3's Avatar
Im using the Hitec 7954 and the servo wire is hella long. It needed no extension.
protc3 is offline
Old 09-03-2012 | 07:00 PM
  #2248
yup, I ended up using a 4" extension on my savox 1268.
nv529 is offline
Old 09-03-2012 | 07:08 PM
  #2249
BashemSmashem's Avatar
I had to use one with my JR 9100T as well ....
BashemSmashem is offline
Old 09-03-2012 | 07:43 PM
  #2250
sramos's Avatar
used hi-tec 7955tg with no problems. hella long with inch or two to spare
sramos is offline
