Tekno RC EB48 Thread
#1487
I think he means he was able to run two 2s packs in the stock tray(like in his pic) , NOT two 2s packs side by side
I doubt there is even enough room on the chassis to do that , not to mention it would screw up the balance that Tekno has worked so hard to achieve .......
. I doubt there is even enough room on the chassis to do that , not to mention it would screw up the balance that Tekno has worked so hard to achieve .......
#1492
#1494
#1496
How about some early driving impressions from those who already have your kits built. How did the EB48 compare to your old rig on the track? Any difference in your lap times? Did you change your driving style? More or less confidence? Too early to tell?
#1497
I am done with my build and am racing it tonight at a local indoor club.
The kit is great and i am a happy customer!
But does have a few minor things to watch out for. When running full droop the tires hit the mudguards while in the air under power. I am running proline wheels with hole shot tires. The mudguards could be easily trimmed for clearance. I just took mine off for now.
Also I did need to sand the front hubs down for clearance because they were sticking when turned right or left all the way (noted a few post ago).
#1499
Might be worth taking off the o-ring on top of the shock body and using Teflon tape on the treads to seal it.
#1500
2Likes
