Team Associated RC8.2e Thread >
Like Tree17Likes
Old 01-02-2013, 01:50 PM
  #3856
heavyjeffd's Avatar
Trader Rating: 15 (100%+)
Originally Posted by CarFanatic
anyone comment on shock oils?
With the Associated 8 x 1.3 tapered pistons, I'm running 45wt front, 40wt rear.
heavyjeffd is offline
Old 01-02-2013, 01:57 PM
  #3857
Trader Rating: 53 (100%+)
is that what the kit comes with? I"m building my kit and on the shocks now.
CarFanatic is offline
Old 01-02-2013, 02:00 PM
  #3858
heavyjeffd's Avatar
No, the stock pistons are non-tapered. You'd be fine with the same shock oil weights though.
Old 01-02-2013, 02:20 PM
  #3859
ok thanks!
Old 01-02-2013, 04:36 PM
  #3860
Trader Rating: 41 (100%+)
I am wanting to upgrade my low- B- plate to the standard-B- plate is this the correct part #89461 for the standard-B-plate? Thanks,
rifraf is offline
Old 01-02-2013, 06:07 PM
  #3861
Didn't ae update the shock pins that hold them in the arm. Mine that came in the kit are really thin compared to others I have seen
Old 01-02-2013, 09:53 PM
  #3862
heavyjeffd's Avatar
http://www.amainhobbies.com/product_...B-plate-w-Pins
The Low B plate uses different pins, make sure you use the pins that come with the Std B plate.
Old 01-02-2013, 09:59 PM
  #3863
Thanks heavyjeffd,
rifraf is offline
Old 01-02-2013, 10:02 PM
  #3864
heavyjeffd's Avatar
Yep.
Old 01-03-2013, 07:12 PM
  #3865
Trader Rating: 38 (100%+)
Hey Jeff you said you run 40 45 weight shock oil with the 8x1.3. Is that pretty standard? I haven't gotten a chance at track time yet but I think I used 37.5 and 32.5 with blue kyoshos . am I so far off I should rebuild them now or give them a chance? Our track gets pretty blown/ rutted out. Its the silver state nitro challenge track
associatevalley is offline
Old 01-03-2013, 08:47 PM
  #3866
joshuabordner's Avatar
Originally Posted by AusOffroader
Hi Guys,
I have been trying to find a solution to my rear cva shield rubber breaking, is there something available that does away with the need to use the rubber to hold the pin inplace?
Seems I am replacing this rubber everytime I drive my car... Hopefully there is an easy fix?
Any help greatly appreciated
P.s I tried the search function but I'm having no luck in finding a solution, my google-fu is also failing today
Edit.. Will a drop of superglue be enough to stop the pin from coming out?
Put a set screw in the coupler with lock tight and that will keep the pin in, the coupler has threads in it already. then just take the boot and o ring off
for my car i am replacing diff fluids whats an all around good setup
thanks, josh
joshuabordner is offline
Old 01-03-2013, 09:12 PM
  #3867
[QUOTE=associatevalley;11606300]How long have you been running your wires like that? Trouble free I'm taking it?
Just finished my first 1/8 build...[/QUOT
What is on the side chassis guard (looks like carbon fiber) i really like it!!
Old 01-03-2013, 09:15 PM
  #3868
heavyjeffd's Avatar
Yeah, I run 45 Front/40 Rear with the AE silvers and AE 8 x 1.3's. It's just the right amount of pack, I don't like a stiff car, it's too hard for me to drive, I like my car on the soft side.
That's also with the Reedy 5500 mAh batteries, which are a big ol' brick.
Old 01-04-2013, 10:41 AM
  #3869
This also depend's on the track and your preference .
Is it smoot or bumpy , high or low grip .
At our track ( bumpy , high grip astroturf ) i use ae blue springs , 40fr/35rr , 8x1.3's , gold swaybars .
other drivers that are using ae silver springs and the stock pistons but they also use gold swaybars becouse they have " griproll "
JEGVGEE is offline
Old 01-04-2013, 10:41 PM
  #3870
princessmocha's Avatar
Hi guys,just got my .2e assembled. Any idea why i had lots of play in the front camber link where the hinge pin goes through? Is this normal or i need to shim it somehow? Thx..
princessmocha is offline
