RC10B4/T4 Forum
Well, Hello, I am new on here. I haven't raced an R/C car for about 15 years or more. When I was just getting out of racing was when Traxxas first came out with its 1:10 scale gas. I never liked gas cars and being the age of 14 or so couldn't really afford the upgrade.
So I decided to get back into it again about 3 years ago and went to the hobby store and bought everything that they guy said I needed and I pretty much knew from before what I would need. Unfortunately I moved from So Cal to Chicago and there isn't any tracks in the city so into the closet it has sat for 3 years. I am moving back to California in 2 weeks and will want to get into it again.
I guess my question is....Most of the stuff I am seeing online is for gas or 1:8 scale trucks. Are 1:10 scale electric trucks still raced on tracks or are they just toys for grandkids now? I don't want to get a gas car, they are just to loud and complicated. Besides that I don't know if what I have is outdated so much that if they still are racing these types of trucks I don't want to show up with total garbage and not be able to compete at all.
So if you could help me out in being race ready I would really appreciate it. I am going to list the stuff I have which is what I bought 3 years ago. Since I was older and could afford the best that they had I bought it, but things change fast.
RC10T4
Novak GTS 17.5 Brushless motor system
Lipo 5000mah, 20c-7.4v
Pro-Peak Quattro plus charger
Airtronics MX-3FHSS
With the radio, I am confused. When I was younger we had little frequency plugs or something like that with numbers that had to match. This seems not to have that. Is that a new thing? When I am around other racers will my radio interfere with theirs?
Any help would be appreciated. Thank You
RC10T4
Airtronics MX-3FHSS
First gas is well on its way out. The electric brushless systems with lipo batteries are out performing them in every way except run time on the large scale cars. I have cars all the way up to 1/4 scale that are electric. I race 1/5 scale touring. The gas cars, even with their longer run time, are barely beating me. I am routinely in the top 5. But this season even that may change, I will be running larger 20,000 mah packs....anyhow back to you.
The parts you have are just fine. If your driving is up to snuff you will run right there. But there can be improvement.
The Novak, to me is a great introductory system. I have never been a big fan of Novak brushless systems. You should see some of the verbal fights Bob Novak and I have had over his systems. But the quality is in there and it will compete well.
Your battery can you give more information. Branding can make a difference. In racing not all batteries are equal. All batteries are fine for practice and bashing but you need the highest, most stable voltage you can get for racing. Lets face it voltage makes RPM. RPM makes speed. Core, Max Amps, Trinity, and the other top line units will provide the most stable voltage under a load. Buy the cheap packs for bashing and practice.
I am unfamiliar with your charger but the charger can make or break a pack. Hyperion and others make chargers that can care for your lipos. The changes in charger technology even just over the last 3 years is a lot. I suggest you buy a new charger. Make sure that the charger you get has compatibility plugs for the balancer on you lipo.
The radios now are generally 2.4 gHz systems and do frequency hopping. Basically that means that unlike your old radio the 'crystals' are digital and the radio reads the the air and hunts for the unused frequency and then locks into that one. This prevents cross chatter between radios. Plus you dont have the 12 inch or longer antenna on the car or the 4 foot one on your radio.
I hope this gives you the information you need.
How can I determine my caster and toe values. Is there a tool I can do this with for my T4? Also just getting back into racing so when making some adjustments dont really know what it does. Is there some info on the web or a book I can get that explains the adjustments on this car?
Thank You
Yes that was extremely helpful.
RC10T4
Airtronics MX-3FHSS
RC10T4
Airtronics MX-3FHSS
I have a different perspective on batteries and I am sure there are more out there that disagree with me than agree with me. Specs are specs. Make sure you have 2 or 3 cell which ever you require, ensure your discharge rate will support the motor/esc combo you have, and make sure the mAh rating will give you the run time you want.
I have been finding a lot of new things from www.hobbypartz.com that are really cheap and seem to be performing really well. The "SkyLiPo" brand batteries have been great. They even have some hardcase that run great.
I have been running this 2.4GHz radio and have been really happy with it: http://www.hobbypartz.com/79p-gt3b-carradio-lcd.html
Just my $0.02
Glad to se you getting back into a great hobby.
As already stated the RC10T4 will do just fine. The motor seems a little on the weak side, but not too bad at all. I have been trying some off brands recently just to compare and have found that a lot of them perform really well. I am currently running a 9.5T Leopard motor and ESC and have been really happy with it.
I have been finding a lot of new things from that are really cheap and seem to be performing really well. The "SkyLiPo" brand batteries have been great. They even have some hardcase that run great.
Just my $0.02
Just my $0.02
Thanks for the help.
Just my $0.02
Just my $0.02
TOADRICK thank you for the good words.
I am going to have to just get to a track and meet some new people and learn about everything again. I was to young to learn about any of the specifics about anything. I am sure in for a rude awakening. It seems like batteries are a big deal. I don't know much about balancing or really what that even is. What a great experiment.
because my friend.. it's not just any b4.. since b4/t4/gt2/sc10 parts are compatible i've realy constructed a BTS4.. some parts i could'nt find in aluminum or titanium for the b4, so i had to improvise.. eventualy after i find the right tires and rims that are'nt wobbly like proline bullshit.. it will be the first b4 to exceed 100mph..
just listed my B4 here for sale:
http://www.rctech.net/forum/r-c-item...ed-extras.html
SC takes up too much of my time for this class also.
Whats up guys I just finished rebuilding my T4 and I thought i'd show it off a little...
She got new:
RPM Front and Rear Arms
RPM Rod Ends
RPM Gear Cover
RPM Spring Cups
Chassis
Rear Plate
Top plate
Thumbscrews
Complete Diff Rebuild
Complete Shock Rebuild
Alluminum Nuts All Around
And Completely Strip Cleaned
I thought since no one around here is racing them I'll make it a shelf queen and bring it out in 20 years, when people are racing cars that make sc look good.
She got new:
RPM Rod Ends
RPM Gear Cover
RPM Spring Cups
Chassis
Rear Plate
Top plate
Thumbscrews
I made this seperate from my last post because of picture limitations
You know the old rtr shocks that were blue alluminum and scratched to silver after some use...well I thought that they looked like crap after a while so I sanded the blue off...I started with 150 grit sandpaper to get a majority off and slowly moved up to 400 grit, I finished off by polishing them smooth and heres what I got.
decent servo for the t4.... moneys tight just looking for something to get me around the track
http://www.losipartshouse.com/servle...peed-Sx/Detail
