RC10B4/T4 Forum
Hey guys, I'm new to 1/10 scale and just bought a used b4. I'm planning on running a Novak ballistic 10.5 and a mmp. I used the search and didn't have much luck. I'm looking for some indoor set-ups on a clay surface. Also what are some pinions and spare parts I should have on hand?
Thanks for any help or suggestions!!
http://www.teamassociated.com/pdf/ca...assic_2009.pdf
This one is a good starting point, it worked great for me.
anyone went to the #2 pistons all around with the blue springs up front?im thinking of 32.5 all around?i know some guys have been trying this with 35 weight all around
Mamba 25 program help
Hey guys I have a mamba 25 for my rc18mt but it won't program I did what the instructions said can anybody help I really want to get back to driving anything will help.
I tried to search for gearing specific to my motor but had no luck. I am running a b4.1 RTR brushless. I geared it taller and I am now running a 78 spur with a 23 pinion on the stock motor. What are you guys running on the stock motor on slow to medium tracks?
My motor is only getting up to 105 degrees max after a 6 minute race.
probly a stupid question but i need some help, is there and alternate wheel nut size for the b4.1 rear wheel? ae 8/32 nuts are on b.o. thanks
In stock at rc10.com http://order.aeteam.net/product_deta...?Itemcode=6952 but there are other companies that make something that size you may be able to ask your LHS to get
You can find that wheel nut size if the hobby shop stocks Du-bro hardware. You may even be able to find it at Home Deopt in the fastener section thought I'm not sure if they go quite that small. .
Most hardware stores will have 8-32.
Gearing/17.5/T4
Could someone please let me know a reasonable starting point for gearing a T4 for 17.5 class. Speedy is hobbywing 60A (as set by club), motor is open and I will use either H/wing 17.5 non sensored or an Epic duo. I have both of those so I will try them and then decide.
Track has straight about 35/40 yds long with lots of tight corners surface is loose dry but mostly run watered down so grip is pretty good. (good enough to wheel stand easily if slipper is a bit tight)
Thanks in advance
Terry
Thanks in advance
Terry
My B4 new paint job
jc punisher body
jc punisher body[/QUOTE]
That is a nice paint job. Classy and flowing.
Has anyone had the problem of having the CVD pin fallout from the CVD in the area right before the rear knuckle?
What tires are you guys using for a clay track?
