RC10B4/T4 Forum
Does anyone know if the new "gold" V2 slipper pads are different than the current version? part number, #9603
shock rebuild
how far out should the shaft rebound from the shock body when pushed up to the shock body after a rebuild?
Generally about 1/4 inch is good. Make sure the shaft bottoms out without any resistance. if you have too much air you will feel the pressure at the bottom.
Is anyone running the new Factory Team rear 1.5° hubs on their B4?? I'm ordering them for my B44 and was wondering if I should get them for my B4??
Adding 1.5* toe is ALOT for the b4 and b44. Ive never needed that much. The .5* hubs are all u need for the b4. I run 1* on the t4 regularily. Why do you want the 1.5* on the b44? I cant imagine a 4whl being that loose.
I should have clarified...I'm ordering .5° for my B44.Should I order them for my B4? The 1.5's are for my FT SC10...Sorry for the confusion
Yeah that sounds about right. You could just order the new arm mounts that come with 2.5/3/3.5/4 degree toe in options and they are only $5. Otherwise yes the .5 hubs are a good tuning option for the B4.
My slipper nut keep coming loose. is it the same nut as the front axle nut? they look the same, but not sure
i think the slipper nut is 4-40.... so the front axle (5-40) is not the same. if your really cheap, just put a dab of locktite on the threads.... i did that once before a qual and it worked out quite nicely
How much do the rtr versions of B4 and T4 cost? How good are they for club racing?
________________________
associated rc8t rs
associated rc8t rs
R/C Tech Elite Member
The slipper nut is 5-40
answer this
What size are the front and rear axles on the t4.1. 1/4 or 3/16''?
Has anyone ran black springs on the rear? I cant find any. Is it normal for the rear springs to touch the camber linkage? Please share any tips you have come up that only requires work not buying anything.. cya in the pits.
i received my b4 today in the mail. im going to use a sidewinder 5700 in it.
what pinion would you suggest i use?
