RC10B4/T4 Forum
ok So I've changed the shock oil on my T4.1(rear shocks) twice now. At first everything is smooth until I go for a few laps and the rear shocks feel really sticky. Why is this happening? I'm using 35 losi oil all around, the fronts are fine.
Changing the oil won't help a swollen set of O-Rings , check for a bent shaft also....
After two weeks the seals are swollen quite a bit ...
Tried this site but having problems getting it to work, it defaults to an academy car and castle creations motor and won't let me change it, any1 else having the same problem??
I have run 17/87 in my T4 with a 6.5. Give that a try to start with.
Ray
cheers ray,
Hows things mate daniel said you retired????
Does anyone have any tires recommendations for B4 for a blown out dusty and dry track? Track is not terribly bumpy but the surface has a good amount of loose dirt on top of a hard packed clay.
I tried X-3000 in Red compound and they were good when there was no loose dirt but terrible in the loose.
Would calibers, holeshots or Goosebumps be the best bet?
Definetly try the goosebumps for that kind of track! Should be good.
Thanks for the recommendations. What about front tires? I tired Losi taper pins and wide body ribs both in red compound. The wide body fronts were more stable for me.
I also have some Losi BK 3 rib Pre-scrubbed fronts in silver compound that I have to mount up yet. Anything else recommended?
Try the Losi red Bigshots or green Goosebumps. A front rib tire from PL, Losi, or Jconcepts would be best.
my local track was kinda blown out and i ran proline wide rib fronts and some super old losi step pins that i think are silvers in the rear. my car was good enough to win and should have tq'ed
Thanks for all the suggestions guys.
I will order up some Jconcepts Goosebumps and another set of rib fronts to compare to my Losi ribs.
I will report back once I get a chance to try these tires.
