Like Tree55Likes
RC10B4/T4 Forum
Old 01-18-2010, 07:10 PM
  #10996
Double Dee's Avatar
Originally Posted by not home
on two vehicles, well 1.5 because it took a package and a half to do one vehicle. and they are junk, basically, my shock bodies were coated in a black and brown coated mess of shock oil and dirt and anything else.
Sorry about your problems. I have them on my b4 b44 t4. change oil every race day . and not 1 problem. 2 times a week.
you started it lMAO
Double Dee is offline
Old 01-18-2010, 07:39 PM
  #10997
Trader Rating: 23 (100%+)
you started it lMAO
lucky you, im back to the originals without one problem. im surprised yours held up with that many oil changes. mine was one and done =/ then the others just leaked, nothing stripped though. im not sure where the oil came from but its not from the bottom of the shock.
not home is offline
Old 01-18-2010, 07:41 PM
  #10998
whitrzac's Avatar
Trader Rating: 97 (100%+)
I've raced them for 4-5 weeks on a offroad carpet track, not exactly easy on parts....
I have one cap that has a slight leak out of the screw hole, just enough to see the oil on the cap, and the screws were never "tight" they just kept spinning(only one leaks a bit). but they make building shocks soooo much easier
whitrzac is offline
Old 01-18-2010, 07:43 PM
  #10999
which is true, they are easy.
not home is offline
Old 01-18-2010, 08:02 PM
  #11000
AssocRacer's Avatar
Hey Mike, i'm using the bleeder caps. Bought em at Trackside. They were really nice. Makes building the shocks a little easier. Stop by my pits at the next Saturday Night Fever race and you can check em out.
AssocRacer is offline
Old 01-18-2010, 08:05 PM
  #11001
sorry to say, but im not going back to them, im not sure if the vcs2 shock caps are doing well in offroad, but i may be interested, anyone know anything on them?
not home is offline
Old 01-18-2010, 08:11 PM
  #11002
SkarTisu's Avatar
Several years ago I used Yokomo shock caps on my AE shocks, which also had a bleeder screw and they never leaked. I haven't gotten the new caps yet, but I don't expect any problems with them.
Is there a chance you overfilled the shock? Maybe stripped the cap when tightening the bleeder screw? I could see them leaking in that case.
They've been on backorder at AE for a while now. I imagine another shipment of them should be arriving soon.
I was told by Brent that VCS2 shock caps won't work because the piston will crash into the bladder at full compression and tear the bladder.
SkarTisu is offline
Old 01-18-2010, 09:44 PM
  #11003
teambighead's Avatar
Originally Posted by one-j-dub
Team,
Can you elaborate on this some more. On the old clips I used to put the two dots facing towards the shock building tool. On the new clips is there any preference which way they are installed?
The two large dots on opposite corners are still on the clip. The new clips have 1-4 very small dots on them.
this shows where the old and new dots are located. The large old dots are recessed into the clip, where the new smaller dots are bumps on the clip.
teambighead is offline
Old 01-18-2010, 09:54 PM
  #11004
astroboy403's Avatar
is it posable to use the B44 rear dogbones+axles in the B4. i like the B44 axles as the have the ring collar to keep the cvd pin from flying out if the set screw in not tight all the way.
thanks
astroboy403 is offline
Old 01-18-2010, 11:01 PM
  #11005
R/C Tech Elite Member
DavidR's Avatar
Hey guys...
I'm running the Maifield Lightweight Setup on my B4 currently and it's ALMOST perfect...
I would however like a little bit more on-power steering...
Got any ideas how to get it without affecting much else in the way the car handles?
DavidR is offline
Old 01-18-2010, 11:15 PM
  #11006
he didnt even fill out half the sheet WTF
Originally Posted by DavidR
Hey guys...
SmItH_aLeX is offline
Old 01-18-2010, 11:48 PM
  #11007
wayboarder's Avatar
Trader Rating: 14 (100%+)
you have to google an image of his car and you will be able to get the rest of the setup of it. The amount of weight and weight placement he adds is interesting. I tried that very setup with the correct weight and the car pushed too much.
wayboarder is offline
Old 01-19-2010, 12:22 AM
  #11008
DavidR's Avatar
I guess I don't know for sure what you're referring too...
Maybe we're talking about a different setup...
THIS is the one thats in my car right now.
http://67.199.85.166/racing/setups/b...assic_2009.pdf
DavidR is offline
Old 01-19-2010, 12:50 AM
  #11009
Emlyn's Avatar
those bleeder caps are junk. lol and here goes the three page fight again...dont start.
Got them on my T4 B44 B4, work great a lot easier to get the same rebound all round and IMO better quality then the old caps, they go on much nicer and freely. Haven't had a single leak or stripped thread.
Emlyn is offline
Old 01-19-2010, 10:25 AM
  #11010
Im going to be getting a rc10t4 within a week. Never owned one before. Whats some things i need to do with this vehicle. Are the stock shocks any good? And what upgrades does it need? I only want upgrades that will make it perform better i dont care about looks. Thanks. If you could send it through pm because i will probably lose this thread!
E-REVO 1/16 is offline
