RC10B4/T4 Forum
R/C Tech Elite Member
ae shocks seem fine to me........
For everyone ..
The caps have always from the beginning been easy to make a mistake cross threading.
Also the thread size has not changed on the bodies or even the new caps....
So cross thread a cap just once and it will always cross thread due to the damage threads...
Even if the caps were metal the same problems would still be able to occur...
So its the not material or the workmanship that is the issue ..
Its the guy building the shock that's the real problem...
I've seen guys with years of experience build their shocks all wrong .
They do stupid things like torque down the cap with wrench way to tight ..
You only need to hand tighten the caps !
Over tight the cap and it will cross thread. Even if threaded on correctly....
For everyone ..
Its the guy building the shock...
X-60
With more time and experience you may change .
I'm no God !
I am just a guy who has raced the B-4 3 days week sense it was first introduce...
sorry you still have not tested back to back gear diff's & ball diff's like I have ..
And sorry again ..
Even your precious GS O rings I have tested and experience how bad they swell ...(That's why they don't leak BDW)
I'm no God !
And sorry again ..
Just want to check the latest facts on the use of Losi pistons in the B4. With Ae shocks and caps that do fit correctly
What size/colour are people using and with what oil?
Anyone tried their springs aswell?
The thread absolutely did change. This is a fact. You could look at my shock bodies next to each other and see the difference. The caps that I was using on the old bodies would not thread onto the new body, the new caps thread on fine. As I mentioned earlier, a factory AE driver confirmed the change.
Orange pistons front & rear work well with 30wt all around or 30/25 front/rear depending how warm it is where you live. Here is Chris Bridgewater's setup (TeamBighead) that should be a good starting point for you
Losi springs are a larger diameter than the AE ones, so they don't sit well in the AE spring collars. Ghea makes some nice collars that allow you to run Losi springs on AE shocks.
wild cherry, im not stupid, i think, wait i know i can screw on a shock cap. and so can everyone else on this thread.
I know that they have had bad batches of caps with their TC style caps, this was confirmed and AE was aware of the issue. As mentioned earlier the plastic caps are just sometimes hard to start and need to be turned the opposite way to kinda seat them so they will start.
X-60
I'm no God !
And sorry again ..
I'm no God !
And sorry again ..
just use to much torque tighting the cap and it will cross thread even if threaded on correctly...
More than one way to cross thread
BDW its not everyone that has the problem...
slight prob...
87/16 spur pinion combo will fit on a T4 with the stock black motor plate, but they won't even touch when useing the FT milled motor plate
