RC10B4/T4 Forum
#9632
if you gear brushless taller they pull more current and thus make more power.
adding to that the torque lowers when RPM goes up, and the taller gearing will thus make the car run faster for a given RPM.
Thus with Brushless you usally get more spin with taller gearing, not lower.
this also explains the wheelies the stockers can pull, gear them low and they are done doing that.
#9633
that's not really correct.
#9634
Gearing taller will tame wheel spin ...
also
A bigger pinion push's the motor further back which will add rear traction...
alert
Too large of a pinion can over heat the motor & ESC... (Bad)
suggest a 22,23 /78 for 8.5 ,T4
also
alert
#9635
only till before the point it only gains in temperature yes.
#9636
are there any "upgrades" or mods I should do before the indoor seson starts???
#9637
Recommend Ryan Mayfield's T-4 set-up for your base set-up ....
start with that....
start with that....
#9638
AE Is Killer Of All......
How good is the T4 out of the Box?
What hop-Ups Are needed?
#9639
For a 8.5 81/23 or 84/23 depending on temps.
For a new T4, there are really no neccessary mods. Only thing I can think of is doing the gt2 front end with arms, caster blocks, and spindals. It adds some strength and makes the truck about bulletproof.
#9640
T4 is pretty tough. only 1 C-hub broken in 25H of runtime orso.
#9643
T4 does not use Gt-2 rear hub , instead use the B-44 rear hub or the stock T4 hub...
#9644
I picked up a used rtr version, dropped a novak 10.5 in it and won almost every race I been in. they're very good outta the box.
simple mods were chose the right tires for the track and brushless. I did win the first weekend with the stock rtr system, but the temps kept going to 200* even geared with 16/84
so far broke 1 front arm, but still finished the race, didn't even notice it was snapped untill going to the pits
#9645
