Like Tree55Likes
RC10B4/T4 Forum
Old 12-29-2005, 05:08 AM
  #886
does anyone have a suggestion for a good servo for the b4. I am new to buggies but have been running r/c trucks for about five years.The b4 is for my team in high school racing so it needs quick response and metal gears and I am thinking of a hitech metal geared servo. If any body has any suggestions the please email me at [email protected] . thanks.
stampeder is offline
Old 12-29-2005, 08:10 AM
  #887
WisRacr1's Avatar
You have mail
WisRacr1 is offline
Old 12-29-2005, 09:48 AM
  #888
Trixter's Avatar
Default MF 1 help
I know this is the MF2 thread but I think this might overlap a little.
I know that the setups that are posted on Losi's site are probably for hard packed tracks. I run on a track that has fluffy/loose dirt and packed jumps, we run it damp.
Here is my question if I soften the suspension just one setting (shock Oil & springs) will I have better control of should I go stiffer?
I have tried the softer settings, and am doing well, bit I am wondering if there is a better way to tackle this.
Trixter is offline
Old 12-29-2005, 10:27 AM
  #889
WisRacr1's Avatar
Are you running Mod or stock class? I know the Mod guys worry about the Oil/Piston matching a lot. What is the truck doing oversteer or pushing?
My questions...anybody having problems with the servo linkage being to stiff?
What is the best way to match tire compound to foam inserts for the track conditions?
WisRacr1 is offline
Old 12-29-2005, 03:48 PM
  #890
Trader Rating: 28 (100%+)
How long have you been racing? The softer suspension will make it seem like your car is giving you more reaction time, maybe making it easier to drive. If it's to soft it'll seem real sluggish and feel like it's not doing what you want it to when you want it to.
If you go stiffer it will react quickly and be more nimble. It's a good thing when it feels like the truck is doing everything you want and doing it quickly. Unless it's to stiff and it's bouncing over everything instead of soaking up the terrain and the rear end won't stay in a straight line. Good stuf to experiment with though. : )
jbrow1 is offline
Old 12-29-2005, 06:56 PM
  #891
Trixter's Avatar
Well I just wanted to be reminded, I was pretty sure that I was going in the right direction.
Thanks again
Trixter is offline
Old 12-29-2005, 07:46 PM
  #892
jamescam's Avatar
Futaba S9451 is what I use and what Jared Tebo used in his B4 that won the Cactus Classic. Another good one is the Airtronics 94360 which is an awesome servo overall.
jamescam is offline
Old 12-29-2005, 08:40 PM
  #893
rivbluenoma's Avatar
Does anyone know if the GMC Sierra body from the RC10GT will fit on a T4?
rivbluenoma is offline
Old 12-30-2005, 12:01 AM
  #894
Tech Legend
Wild Cherry's Avatar
It can be made to fit , but you should go with a T-4 body unstead.
It will fit & perform better....
Wild Cherry is offline
Old 12-30-2005, 05:53 AM
  #895
WisRacr1's Avatar
Need help with this guys. I know that there is a way to find out what's needed Foam-tire match per track that you race....I just tneed to know how I go about figuring it out on my own.
WisRacr1 is offline
Old 12-30-2005, 03:58 PM
  #896
Anyone know of any other message boards specifically for the T4? Nothing against this one I'm just looking for a little more info. It's a fairly popular truck so I would think there would be a few more forums on this truck.
tjnitro is offline
Old 12-30-2005, 06:37 PM
  #897
Check these boards out. Any question you have can be answered by Mystracing, or Charlie Perez there. T4/B4 Forums
jbrow1 is offline
Old 12-30-2005, 07:54 PM
  #898
Thanks very informative.
tjnitro is offline
Old 12-31-2005, 08:56 AM
  #899
WisRacr1's Avatar
Hey on the topic of the B4 can some of you guys tell me what spring/oil set-up your using for your fronts and rear shocks?
Thanks!
WisRacr1 is offline
Old 01-07-2006, 07:06 PM
  #900
Wis, go to the link I posted a couple replies up. You'll find some good setups there, and tons of info for the B4.
jbrow1 is offline
