RC10B4/T4 Forum
#8461
Yeah, the timing boost is only needed in stock or spec classes, but there's a lot more to it than that. What happens if you have a sensor go bad or cable comes unplugged? The gtb stops and the lrp catches fire...lets say I wasn't happy when that happened on my LRP.
Wild Cherry, AE needs to hire you for all the representin' you do.
Its too bad the SXX is slower than the SPX with spec motors.
Also, I find it irritating when I have to completely remove the esc from the car to put on fresh wires.
I`m not representing LRP !
I`m just satisfied customer.....
#8462
Suspended
AE Is Killer Of All......
Buy a Tekin you'll be happy with it Guaranteed !!
#8464
Opinion on front tires please?
Do you run front tires, like proline edge? or do you use rears like holeshots on all 4 wheels?
when do you use front specific tires? when rears on the front wheels?
this is oriented towards the truck.
#8467
seems like the edge is gonna be alot needed then.
Thanks guys.
Thanks guys.
#8468
So you guys are saying for clay/hard packed tracks run edge type tires, and for looser, dusty tracks run something like bow ties, or holeshots?
How would suburbs do on loose-ish tracks? http://www.amainhobbies.com/product_...ucts_id/141348
Is there any parts of the B4 that should be upgraded right away, or just see what breaks etc? I saw a couple people running aluminum front caster blocks at pegasus... Is this common?
#8471
#8473
Your b4 should be fine from a durability perspective out of the box. As you break parts, stick with plastic (as opposed to carbon $$) to gain a little more flex and durability.
#8475
I wouldn't suggest switching to plastic on the front a-arms. When I use to have a team kit with plastic arms I would be lucky to make it through a day without breaking atleast one. Finally I tried th FT ones and I never had one break up until I sold the car. Now that I've got a FT B4 I have yet to break an a-arm. So even though I've been told I'm absolutely crazy and that the FT ones are less durable from my experience they are not, stay with the FT front a-arms and you will be happy.
