Traxxas 2wd Slash Thread
#1786
#1787
I'll try the steel wool trick.
I ran my truck today outdoors on loose dusty and then indoors on a very tight technical carpet track. Wow this truck is made for high grip and tight! Very impressive how tight it could turn. I ran 5-5-3 in the diffs and it was dialed.
Now I ran blue springs with 50 wt oil in front and orange rears with 45 in back with blue pistons and stock sways. the truck had body roll but I think it needed it, should I go up in rear spring?
I love my friggin truck.
I will order the shock bodies for sure.
BTW does anyone use the shock shaft boots to protect dirt from getting on the shaft and inside? the tracks I run on kick up so much dirt on the rear shocks. grrr.
#1788
b4.1/.2 driveline questions
A few questions for MIP MATT or anyone else that wants to chime in with their opinions. I will list them for ease of viewing
1: Will there be any performance differences in using the MIP outdrives for my diff in my b4 other then longer life?
2: Are the stock AE diff outdrives made out of a softer metal on purpose? for example does it gain more traction due to possibly different binding characteristics during the dog bone plunge effect?
3: I imagine i will wear out the stock AE cva driveshafts faster?
4: Does MIP sell replacement pins for the driveshafts like you would commonly see in an 8th scale driveshaft?
5: I understand that cvd's have different handling characteristics, would it be best to use them with the MIP outdrives since i imagine both the outdrives and driveshaft are both of a harder material? And if so, what exactly are the handling differences? I have heard the car squares up better but may not go through bumps better, is this just a theory?
Thanks for reading!
Thanks for reading!
#1789
our race track thread with videos here in Durham, NC, USA
This racetrack is called Pines RaceWay or Pines SpeedWay. It has been built at least ten years ago. Through that decade+, the track has been modified and improved. The surface is a combination of a small layer of topsoil and the rest is made of clay. We continue to test the layout of the track. Recently, we patched the jumps because of wear and tear from constant use. We also filled in some sections of the ground to make it flatter and more level, for a smoother and faster speeds. The race track needs maintenance, mainly during the Fall and Winter seasons, because of the fallen pine straw, pine cones, twigs, and dead leaves. After a thorough clean-up, we can race from the months of January to, I'd say, late October, at this outdoor race track. I will post our videos onto this thread, so that they will all be in one place. In the first few vids, we aren't really going that fast at all. We are currently running stock class Short Course trucks with the VXL systems mated with Traxxas 3000mAh 8.4V NiMH batteries. I'm waiting on the four IP Intellect 2S 80C 7200mAh LiPo battery packs I bought online from rcMart.
+ YouTube Video | |
+ YouTube Video | |
+ YouTube Video | |
+ YouTube Video | |
#1790
What front tires are you guys running? I'm gonna be running aka gridirons on the rear...do these work well on the front?
#1791
Suspended
Been messing around with ByPass1 pistons on my 22 buggy and SCT, and I must confess these things are IT!!!
They're especially noticeable on the SCT that now soaks the little bumps and ruts like they're not even there.
Thanks Matt and the MIP crew.
#1792
Hey Matt I ran your smac trac setup last night , I need a little more turn in seems some tight turns I have to wait on it .l,what would you suggests changing
#1796
Matt are you seeing any benefit of the big four shocks over the normal 10 mm #a B 4 or a T4 sc10 with the mip piston and what are they
#1797
http://www.teamxray.com/teamxray/sho...p?file_id=4461
#1798
Thanks for reading!
Thanks for reading!
Hope this helps man and thanks for the interest in MIP
Regards,
Matt
#1799
Hey Matt it's a small indoor track , it has a lot of 90 degree turns ,so hard to,pitch , I will try 5 in the center and see if that helps. Thanks
#1800
Try dropping down to 2k in the rear if you don't get the result you're looking for. I like my truck to rotate on it's own rather than drift like Matt does. My 2 cents.
