Serpent 811E Buggy Thread >
Like Tree5Likes
Old 01-29-2012 | 11:52 PM
  #1336
porkchop's Avatar
Originally Posted by rcfreak2
yea thats was my gess but wasnt sure haha... its gona be insane carnt wait to try it lol
more like come of the conor and go back to the future lol
porkchop is offline
Old 01-30-2012 | 12:10 AM
  #1337
haha can see it going str8 off the sweeper at end ov str8 into bushes ..lol
rcfreak2 is offline
Old 01-30-2012 | 10:10 AM
  #1338
Some attempts to simplify my Snake. A special bracket for the servo/esc is in process.
puttekula is offline
Old 01-30-2012 | 03:33 PM
  #1339
porkchop's Avatar
i am pretty sure you just waisted a 200 dollor speedo form what i been told you can remove the cage it connected to part of the speedo inside. good luck
porkchop is offline
Old 01-30-2012 | 03:57 PM
  #1340
rcjunky10's Avatar
Chop, the ESC is fine. You're only cutting off the plastic cage with a cut off wheel, which has 0 impact on the ESC's performance....assuming he doesn't need to run a fan....that's a different issue!
rcjunky10 is offline
Old 01-30-2012 | 05:46 PM
  #1341
fievel's Avatar
If you cut the cage too low it voids the warranty. The up rights help hold the heat sink on.
fievel is offline
Old 01-30-2012 | 05:58 PM
  #1342
porkchop's Avatar
once the heat sink pops off so does the bce
porkchop is offline
Old 01-30-2012 | 06:34 PM
  #1343
bigjayjay1's Avatar
I don't know why you would do such a thing it works perfect as OEM now you just decreased the whole value of your items. Different strokes for different folks but man what a waste of time just my personnel feeling
bigjayjay1 is offline
Old 01-30-2012 | 07:18 PM
  #1344
rcjunky10's Avatar
Default Gearing
Boys, how are you guys gearing an rx8 paired to a T8 1900kv on a large outdoor track? Been running the kit 16t and it seems very comfortable.
Old 01-30-2012 | 07:45 PM
  #1345
porkchop's Avatar
i would go to a 17
porkchop is offline
Old 01-30-2012 | 10:57 PM
  #1346
Well, after 1,5 season it still havent popped off. And if it do, Ill by me a new one. And no problems with the heat what so ever.
Honestly, I think the whole area around the servo is much to complicated. As the battery boxes and
antiroll bars. Is there really a need for bearings there? And what will happen when dust/dirt will
collect in the connections at the arms?
I really like my Snake but in some areas it’s a bit overworked. And the weight confirms that.
Old 01-30-2012 | 11:16 PM
  #1347
jsamarin's Avatar
a new case is only $10, so its not the end of the world, however the side pieces keep the heatsink / boards tight in the case. with out this pressure holding it down, the whole assembly rattles around in the lower case, and can cause pre mature failure. The esc looks way better with out the cage though
jsamarin is offline
Old 01-31-2012 | 01:09 AM
  #1348
porkchop's Avatar
in 1.2 years i have had a issue with dirt and the sway bar ball and nut in the arm. and it was a weekend i did not clean my car or look at it.
when i clean my car i make sure to blow the hole out and the dust goes with it
and yes the bearing smooth things out. and it pimp
the radio try imo is the sweet 5 screws and the motor servo esc are all in my hand and the cars ready for the simple green and water hose
porkchop is offline
Old 01-31-2012 | 10:07 AM
  #1349
5 screws here as well. And thats inkluding the steering rod. Are you using any contacts between esc and motor? Do the motor really like water?
Old 01-31-2012 | 11:38 AM
  #1350
Maxxingout's Avatar
T8's are not water proof. Some wetish dirt/clay is ok but don't go taking a garden hose to the motor.
Maxxingout is offline
