Serpent 811E Buggy Thread >
Like Tree5Likes
Old 11-03-2011 | 06:54 AM
  #586
Posvar's Avatar
Moderator
Don't recommend it but also the OFNA Nexx8.
Posvar is offline
Old 11-03-2011 | 07:08 AM
  #587
And Team C T8E. In USA more known as TQ Racing SX8E, in Europe - Ansmann X8E.
audriusv is offline
Old 11-03-2011 | 08:30 AM
  #588
Maxxingout's Avatar
well looks like my buggy will take longer to finish than I'd hoped for. I've been waiting for my amains news letter so I can use the $75 coupon code on my order. Just found out they no longer carry that code amymore
Maxxingout is offline
Old 11-03-2011 | 10:38 AM
  #589
bigjayjay1's Avatar
Check our absolute hobbies highly recommended.
bigjayjay1 is offline
Old 11-03-2011 | 11:17 AM
  #590
Maxxingout's Avatar
do they have good savings, like the $75 off of a $750 order?
Old 11-03-2011 | 11:26 AM
  #591
porkchop's Avatar
call and ask for joe or chad and tell them porkchop sent you they take care of you
porkchop is offline
Old 11-03-2011 | 11:27 AM
  #592
bigjayjay1's Avatar
OCT05AHZ $5
OCT12AHZ $12.5
OCT25AHZ $25
OCT75AHZ $75
Change OCT to NOV
Old 11-03-2011 | 01:15 PM
  #593
Frank L's Avatar
Originally Posted by ronsand
Hyper 9e and Caster to mention at least two more..
Caster where??
Frank L is offline
Old 11-03-2011 | 09:40 PM
  #594
Originally Posted by Nogas
Hey Jason! Sweet, how do you find they compare? I've heard from a few guys who've moved from mugen saying that the serpents are harder to set up but once dialled they are very happy. I was very impressed by the quality of the finish.
I am liking it so far!
So what servo's are people running/recommending to run in this snake? Also for those that already have them, can you share what weight oils you started out with all the way around, did you start with the factory settings?
Originally Posted by Frank L
For steering servo it's hard to beat the savox 1268's they don't break the bank and they perform great. My favorite servo is the KO rsx line. They are definatly at the top but they do stress the bank a little.
For fluids I started with the same as I run inthe nitro buggy 40 front and 30 rear with 5-5-4. After running the car I would bump the center fluid up to at least 7 as the front just unloads and turns the front tires into pizza cutters immediately when you pull the trigger hard. So prob 5-7-3 and 40/30 in the shocks with 1.3 pistons and maybe go up to 5-10-3 if the front still unloads.
I had to got 5/7/3 from the stock 5/5/3 cuz the front was unloading. I might even go up to 10 in the center cuz it still does it a little bit. Oils are 350/300 and I stiffened the front shocks to pinks and lightened the rears to greys
How are you going to make 15 mins with a 2250?
I am hitting 12 mins or so with 5200 and a 1900
12min with your 1900? I'm making 17-21 min with my 1900 on a similar 5300mah turnegy pack(s)
jasonwipf is offline
Old 11-04-2011 | 01:59 AM
  #595
With my buggy (2x2S LiPo, Tekin 1900 + RX8, buggy weight ~3.5kg) I burn ~260-280mAh per minute. Typically after 10 min main and some warm up laps my charger puts ~3300-3600mAh in my 4400mAh 35C batteries.
Caster where??
Caster Racing EX1.5R 1/8 buggy
http://casterracingusa.com/product.p...&cat=60&page=1
I think it is already ~3 years on the market...
audriusv is offline
Old 11-04-2011 | 05:09 AM
  #596
Frank L's Avatar
If the front is still unloading then try stiffer springs in the rear. There is too much weight transfer to the rear if the buggy.
I'll try a times run on Sunday. I haven't actually put it on the clock yet.
Frank L is offline
Old 11-04-2011 | 06:37 AM
  #597
Maxxingout's Avatar
I'm in the middle of my buggy build, MAN is this thing nice! Looks like I'm gonna have to get the truggy in the spring time for outdoors.
Old 11-04-2011 | 08:30 AM
  #598
Frank L's Avatar
The truggy build is just as nice. But this e buggy definatly rocks the cool scale.
Frank L is offline
Old 11-04-2011 | 11:39 AM
  #599
Maxxingout's Avatar
I have 3 questions for those that have already built the car. 1: does the FR FR on the front diff supposed to have protruding nubs like the back diff does? You can se in the pic that the diff housing has the clearance just like the rear but the FR FR does not have the nubs on them?
2nd: after fully assembling the rear I'm getting about 1.7mm of back and forth play on the a arms? the fronts have none, is that normal?
3rd: is the 0 inserts supposed to have "0" offset? Imeasured them with my digital calipers and they measure off by about .02. Also the #6 for the rear measures right in center?
Old 11-04-2011 | 11:57 AM
  #600
Chad Millikan's Avatar
1. I dont know about the nubs you are talking about
2. My nitro does have a little back lash, I am thinking cause of the toe angle, if they were squared up they would be a little tighter.
3. You have the wrong number for the rear toe blocks. attached is the rear anti-squat and toe diagram.
File Type: pdf
Chad Millikan is offline
