Serpent 811E Buggy Thread
#5072
#5073
Well, summer is here and that means my motor temps are sky high.. I am running a Tekin 1900 gen 2 combo geared 17/46.I feel like my top end is not excessive, and this gearing works for the rest of the year except the summer. I just rebuilt the buggy so I do not think there is any excess drag anywhere. At practice today I was running the buggy fairly hard, but after an 8 minute run my motor would be 180ish. On a 10 minute run my motor hit 208. Around here we run 10 minute mains, so I need to get those temps down. I was thinking of dropping to a 16 tooth pinion, but I am not sure if that will make enough of a difference. Any other suggestions? My ESC setting are fairly mild as well.
#5074
#5075
Ok, I just ordered a 16 tooth pinion so I will try that this weekend. I will check my ESC settings. I think my timing is set to no more than 10 degrees. I believe my current limiter is somewhere around 85, so I will turn that down a little also. The body I was using did have a vent hole over the motor. I am going to clean up my buggy some and check the bearings this week. I will mess with the current limiter more when I practice on Friday.
#5076
Man, that's not what I wanted to hear. I'm currently running a 2050 with 16/46 and I'm about to switch to 1900 and was going to run a 17. Probably close to 90deg when we start racing here. If I go to a 16, my SCT top end is going to be faster than my buggy, at least by the calcs.
#5077
16/46 gearing
#5080
#5081
Hey guy's, finally got delivery of my new 811be rtr 2.0!.
Must say i'm very pleased with it now that it has 2.0 diffs, 2.0 rear suspension and threaded shocks!
What was a good value rtr is now a great value rtr
I do have one question though, it has a 46t center spur and an 18t pinion. I was hoping to put a 16t on for the warmer months if needed.
Only issue is that the motor is just barely off the chassis now!
How are guy's fitting down to 15t pinions?
I know the kit chassis has milling work under where the motor sits but i cant see it allowing that much more room to move.
#5082
#5084
I am using the same set up. My motor is brand new and runs at the same temps. My motor runs at between 180-220 on a normal summer day. My esc settings are bone stock but with the added 7.4v on the bec and the 4s cut off.
#5085
The motor is probably about a year old, but does not have a ton of time on it. I have a gen 1 motor that just got new bearings and a new rotor, so if my gen 2 motor is still overheating I will try that motor to see if it makes a difference.
5Likes
