Serpent 811E Buggy Thread >
Like Tree5Likes
Old 09-13-2012 | 08:15 PM
  #2986
Throttle worx are great as well with amazing service and the batteries are wicked good
todb is offline
Old 09-14-2012 | 02:37 AM
  #2987
Toughbeard's Avatar
we use 5300 to 5800 batteries. I personally have TP 5300 which are lighter so the car feel better and lighter.
One of our friends made the following after his first run...
Toughbeard is offline
Old 09-14-2012 | 05:58 AM
  #2988
Do you guys put any kind of lube or green slime on the shock o-rings when you install them or should you leave them dry? Just trying to get the smoothest possible shock so any suggestions would be great.
JoeC is offline
Old 09-14-2012 | 06:22 AM
  #2989
Toughbeard's Avatar
I usually put shock oil on the threads of the shock piston and orings when building so that the threaded parts goes through the o ring without damaging them. I used to use green stuff but smells bad
Old 09-15-2012 | 11:31 AM
  #2990
Maxthepersonz's Avatar
Just out of curiosity. Why doesn't Serpent make a 1/10 buggy? That thing would absolutely dominate.
Maxthepersonz is offline
Old 09-15-2012 | 11:33 AM
  #2991
Toughbeard's Avatar
who told you Serpent is making one????
Sssshhhhhhh dont tell anyone
Old 09-15-2012 | 12:12 PM
  #2992
I think you'll see a Serpent 2wd buggy out before you see a Serpent 4wd SCT. I'd love to see a Serpent 1/10th 4wd buggy out as well.
Stealth_RT is offline
Old 09-16-2012 | 06:07 AM
  #2993
Need some setup help, trying to battle on-power understeer.
Heres what im running
Diffs 5-7-3
Shocks Green (5.4), Green (3.4). Might try Yellow Rear springs.
45wt front, 35wt rear.
Rest is setup like Porkchops setup, apart from im using Steering Option 3. Also im using stock pistons in shocks.
What to adjust?
jasjeet is offline
Old 09-16-2012 | 06:18 AM
  #2994
Working on a shock setup for our local track and wanted to see what you guys would suggest. I run on a large 1/8th scale track with a lot of medium size jumps, a little blown out, and loamy.
I am currently running white rears, 8 hole conical pistons, 25% rebound w/40w and blue fronts, 8 hole conical pistons, 25% rebound w/35w.
Car feels pretty planted but seems to not handle the rough section as well as i would like. Any suggestions would help. Thanks.
JoeC is offline
Old 09-16-2012 | 09:57 AM
  #2995
Toughbeard's Avatar
check your droops.
fronts we usually use greens and rear whites. 500 - 800 oil conical8 pistons.
our track is real rough with extremely high jumps and no landing ramps... so they need to dampen alot of hard hits.
Shocks I use 100% rebound 3 sec deploy time to full length.
Old 09-16-2012 | 10:06 AM
  #2996
Im using 8 hole conical front and rear.
Front: green springs/400cst
Rear: grey/green springs/300cst
That work perfect for me, when the track is bumpy.
Dont know about your running kick up in your front? But that will help your car a lot!.
Magnus
Magnus F is offline
Old 09-16-2012 | 10:28 AM
  #2997
What effect do the 8 hole conical pistons have compared to the stock ones?
Also can someone tell me what Shock Length at full droop means?
And what effect do the downstops have?
One more question, to lower ride height do you loosen or tighten the shock collar?
jasjeet is offline
Old 09-16-2012 | 03:07 PM
  #2998
Anyone using the black or blue CSI pistons and if so how do you like them and what setup are you using? Thanks.
JoeC is offline
Old 09-16-2012 | 03:12 PM
  #2999
Toughbeard's Avatar
the new conical pistons are machined from delrin which is a self lubricating material with has much less surface resistance compared to molded plastic. the number of holes and hole diameter determines the pack and the dampening of the shock it self.
Shock Length at full droop: the length of your shock measured when the downstop screws are not engaging the chassis to change droop. this is usually the shock length but in some cases the normal length of the shock can be longer than the full droop length.
downstop adjustment allows you to limit how much your suspension travels downwards.
when the collar is closer to the top of the shock your ride height lowers... so you unscrew it to lower the car and screw in (downwards) to raise the ride height...
Old 09-17-2012 | 06:18 PM
  #3000
Hey guys what batteries can I run in the buggy? hard case or soft case. I wonder since some hard case battery cables come straight up instead of the front and I'm not sure they I will be able to close the battery "cage" with those connectors?
Thanks guys
TXSlasher is offline
