Serpent 811E Buggy Thread
#2281
they prob didnt include the 0.1mm shims cause IMO they are not needed, I used the 0.2's and yes the drive train was tight but it broke in nicely. What kind of wrenches are you using? I used a electric driver with EDS tips, I ran they screws in and then took them out and put them in again. Much easier that way.
#2282
Tony i use Hudy tools. I was wrong when i stated "Poor quality plastics" i mean poor quality mold or finish, since the problem i've found out in the diff.l case is about the seat of the 25mm's screws. , actually the hole is to narrow to allow the allen screw to go all the way down and sit in place.
#2284
#2285
I looked through both the nitro and electric manuals, and I didn't see this part (600489) listed in any of the step by step instructions, or any of the blow up diagrams (almost typed 'doll' instead..
) ... only place I found it at all, was the electric manual in the parts listing.
now Im really curious, so maybe one of the team reps can comment?
) ... only place I found it at all, was the electric manual in the parts listing.now Im really curious, so maybe one of the team reps can comment?
#2287
#2288
Going to try porkchops setup, im aiming for Blue/Green (5.0/5.4lb) in the fronts with Yellow/Green (3.8/3.4) in the rear. And 40/30 oils front/rear.
I bought my car 2nd hand and the diff oils are setup as so: 5k, 7k, 3k front/mid/rear, should i change it to the usual 5k 5k 3k? What effect does a thicker centre diff have on the car?
Also people are using webbed bladders, do i need this? What do they do? And also people changing the shock piston, whats the stock pistons used? How much effect do these things have overall?
#2289
^ right off the bat, Im using web bladders + CSI pistons (new black). the Sperpent upgrades have done pretty well too.. not sure who is running the stock pistions and having good luck with them.
A thicker center diff will you give you better acceleration, and put more focus of "diffing" action to the front and rear.
Typically, for nitro, I like to run 7-10k center, but for this e-buggy, 5k seems to be plenty so far, unless the track is really rutted and blown out, then drop down.
The webbed bladders hold their contextual "form" and don't "collapse" like the stock ones, which cause the rebound of the shock to be affected and also potentially cause the shocks to leak. Otherwise, put Losi foam compensators in the stock ones.
#2294
Absolute Hobbies has some.
http://www.absolutehobbyz.com/produc...oducts_id=4303
Sorry, forgot I was in the electric thread...
#2295
5Likes
