Like Tree5Likes
SC10 4x4 Thread
Old 01-04-2012 | 12:38 AM
  #13936
BlueGlowBoy's Avatar
Originally Posted by spencerracing00
ok i have the lrp 5.5 short course motor in my 4wd and it seems to get warm quick and real "lazy" feel my brushed slash is almost faster than it. i also have the mamba max pro esc.......what can be wrong??
I had the same problem with my Tekin 5.5. It wasn't the motor, it was the slipper (which in turn, heated up the motor). Replaced with RCShox garodiscs and problem was gone. You could accomplish similar results with Mac's Clutch Basket. 5.5T 550s have too much torque for the AE slipper pads to handle.
BlueGlowBoy is offline
Old 01-04-2012 | 12:51 AM
  #13937
CoyoteSlash's Avatar
Originally Posted by MantisWorx
same here, will try to take a better look at it in a few days.
As Far as these Bushings<Bearing modification to the Diffs:
I have things marked up and am heading to the shop in the morning to do the cutting. Hopefully I can get some bearings asap and start Testing.
I will put it through the paces. And show some video proof.
Mantis, If this works out, You can work on some prettier or better engineered version. I'll try to fill the void until then.
CoyoteSlash is offline
Old 01-04-2012 | 03:15 AM
  #13938
IRM616's Avatar
Originally Posted by B ELDRIDGE
I think I may have found a way to fix wobbly diffs. You cut down where the 10x16x4 bearing rides to about 1.25mm tall, then you can place a 5x10x3 bearing(AE91156) inside the other bearing for the outdrives to ride in.
Attachment 856485
Attachment 856486
Attachment 856487
Attachment 856488
So do you have two bearings on eachbside? Thanks
IRM616 is offline
Old 01-04-2012 | 03:57 AM
  #13939
Old 01-04-2012 | 05:06 AM
  #13940
Yeah Racing just popped these out. Our AE FT ones are 'perfectly' fine but someone will want them. They're pretty.
http://www.yeahracing.com/catalog/ye...10-p-3178.html
Old 01-04-2012 | 07:46 AM
  #13941
skengines's Avatar
Those look nice, but I'll stick to my AE aluminum hexes.
Anyone have extra springs laying around? Also looking for the front/rear sway bar set.
skengines is offline
Old 01-04-2012 | 08:25 AM
  #13942
LouDawg's Avatar
I added 5oz of lead weight throughout my chassis to get a good balance.
I really like the way it is running at the moment and was wondering what you all are seeing at the scales.
I weighed my sc10 4x4 in race trim (body, battery, wheels, amb, etc) and came in at 6.15lbs or 2789g
LouDawg is offline
Old 01-04-2012 | 08:28 AM
  #13943
Chad Smith's Avatar
Switched to saddles and all I can say is wow! It is a huge difference between stick packs and saddles. Did anyone else gain even more steering when switching? I also gained traction. But I also noticed if I am not perfectly straight coming out of a corner if I get on the throttle to soon my truck still wants to spin out. Any tips? Will thicker front diff fluid help with that promblem?
Chad Smith is offline
Old 01-04-2012 | 08:43 AM
  #13944
FRONTI3R's Avatar
Default JConcepts pre-mounts on +3mm Hazard wheels
FYI
NEW JConcepts pre-mounts on +3mm Hazard wheels for our SC10 4x4.
http://www.shortcourse.eu/2012/01/jc...hazard-wheels/
FRONTI3R is offline
Old 01-04-2012 | 08:55 AM
  #13945
vito's Avatar
hey i get my truck to day in the mail later time to read up from the best.
vito is offline
  #13946
Chad Smith's Avatar
Is anyone running Proline wheels on there truck? Which ones have the correct offset?
Old 01-04-2012 | 09:02 AM
  #13947
Proline Protrac rims have the same offset as the stock wheels. Some had issues with wobbly rims when the truck first came out, but I didn't have any issues with them.
Krio is offline
Old 01-04-2012 | 09:04 AM
  #13948
Chad Smith's Avatar
Ok cool.
Old 01-04-2012 | 09:05 AM
  #13949
vito's Avatar
Ok cool.
http://prolineracing.com/wheels/prot...-black-wheels/
vito is offline
Old 01-04-2012 | 10:22 AM
  #13950
Thomas P's Avatar
Ordered one truck today and a lot of spares..will use my Castle SCT Pro 4600 system..
Read about the Clutch basket system..does every racer run this?..it will only use 2s Lipo and that system..is this a must??
do not want to order anything that is not needed, please let me know
Tp
Thomas P is offline
