Like Tree5Likes
SC10 4x4 Thread
Old 05-16-2011 | 09:47 PM
  #1291
Originally Posted by SaladFork
No heat issues at all... It will handle up to 4S with the 550's without a fan.
I wish viper would get there web page back up so I can get more info.
buckeyeboy30 is offline
  #1292
Wild Cherry's Avatar
Tech Legend
Originally Posted by Odin544
can someone explain the advantages , disadvantages to running the emulsion style vs using the bladder in the shocks?
Bladders will give the shock more pack, good for jumps & landings .
Emulsion give more traction, better side bite & forward bite.
Wild Cherry is offline
Old 05-16-2011 | 09:50 PM
  #1293
bigs's Avatar
Originally Posted by Ron Meloni
Anyone else have this issue? While building my kit yesterday (Sunday) I noticed one of the front dog bones was not cut to accept the pin that secures it to the axle. I called AE this morning and was told it was the first they had heard of it, but are sending out a replacement right away. Awesome customer service for sure, just hope it arrives quickly so I can hit the track Wednesday night for its maiden voyage.
I thought I had the same prob. But I found that a washer from the parts bag fell into the output and the bone would not go in. Hope this helps
bigs is offline
Old 05-16-2011 | 09:55 PM
  #1294
Odin544's Avatar
Originally Posted by Redbeard
I know it was asked a while back but I don't think there was a clear answer...can anybody provide any input regarding the advantage/disadvantage to running the shocks with or without bladders?
I've built them both ways with the supplies in this kit and the only difference appears to be that the non bladder (without removing upper X-Ring) build seem to be a bit more smooth/plush while the one with the bladder is a bit more stiff/less plush. No leak either way assuming you use the correct seal on the cap.
http://www.rctech.net/forum/electric...er-shocks.html
After reading through this I decided to run with the bladders.
Odin544 is offline
Old 05-16-2011 | 10:00 PM
  #1295
Tech Legend
Originally Posted by Gas Rat Racin
Has anyone tried the overdrive pulley gear on the front? I run on a fairly big outdoor 1/8 track and tends to get pretty loose when it dries up. I was wondering if running the overdrive gear would help on accelerting to keep the truck straight? Thanks for any ideas.
Don't think the 19T pulley is what your looking for , you would get even more steering coming out of the turns, also steering will feel faster or more reactive.
The 19T pulley best use would be on really small & tight layouts like you find indoors....
Old 05-16-2011 | 10:24 PM
  #1296
Racecrafter's Avatar
Originally Posted by Matt Howard
so can anyone either confirm or debunk the myth that "slash rear" offset wheels can be used and still be under legal width? I've got a crap load of tires mounted on slash rears I used for my Blitz ESE, just don't have my SC10 4x4 yet (thursday according to fedex)
It brings the truck to 300mm. 4mm too wide.
Racecrafter is offline
Old 05-16-2011 | 10:39 PM
  #1297
murky123's Avatar
Originally Posted by JEFFs SC10
I see people in Netherlands have received their trucks and I still haven't.. What's wrong with this picture? I guess I thought by pre-ordering I'd be one of the first to get one.
Yes this is what I'm contributing today.
I guess I know my way around ..
you will get yours soon enough
murky123 is offline
Old 05-16-2011 | 10:43 PM
  #1298
Originally Posted by CraigV
Remove the upper X-Ring, #91055, this will free up the shocks and takes a lot of the stiction away and the shocks will feel much smoother. Don’t forget that the shock cartridge seal tube is directional!
That is in the first page and was suggest by Chris Jarosz from AE.
Try it out and let us know how that works.
Craig, your thread has blown up today!
The single x ring is smoother but still binds you can still feel the lips on the x ring fold in. I also have clearanced the cap for the shock shaft as I feel this is also a little tight. I have o-rings coming that should be here tomorrow. I'll let you and the thread know how they feel and work.
Old 05-16-2011 | 10:44 PM
  #1299
SaladFork's Avatar
Product updates are coming... those are next on the to-do list.
SaladFork is offline
Old 05-16-2011 | 11:14 PM
  #1300
Waldo183's Avatar
Default Weight in front left of chassis
I've seen a couple of the set up sheets mentioning adding weight to the front left on the chassis... Is there a reason for this? Perhaps to level out the weight of the car? Someone more knowledgeable than I please answer...
Waldo183 is offline
Old 05-17-2011 | 12:12 AM
  #1301
CentralCoaster's Avatar
Originally Posted by Jenzorace
After further investigation. The slipper thrust spacer part number 91090 on the top shaft was machined short. It made the pulley rub the trans case. Thats how i found the problem. I used some shims, and bench tested it. No slippage. Whoever machined these parts need to turn up the chuck pressure on the lathe. Now we have to wait. Or find some shims to take care of this problem.
91090 was not machined well on mine either. I had to run a drill through it to clearance it enough to fit over the shaft.
CentralCoaster is offline
Old 05-17-2011 | 12:14 AM
  #1302
One of the guys on socal put xrings in his 2wd awhile back and said they were very sticky initially but after awhile smoothed out.
Old 05-17-2011 | 01:40 AM
  #1303
Ridley's Avatar
This is not correct.
A bladder shock will have more pack than an emulsion shock, with the same oil and same piston...but thats because the oil doesn't become an emulsified froth in a bladder shock. When the air and oil mix it becomes "lighter" in viscosity. While going lighter in oil increases traction and decreases pack, it does so equally in both style shocks, just far more consistently in a bladder shock as there's no way to correctly gauge the amount of air is actually in your emulsion build, and there's also no changing from start to finish as the oil and air are in different stages of emulsion.
Having a bladder allows you to build your shocks with more, and more consistent rebound. Faster rebound creates more traction as it keeps your tire on the racing surface. It also keeps your shocks consistent from start to finish of a race, as the air and oil never mix.
IMO, there is little, if any, reason to ever do an emulsion build over a bladder build.
Ridley is offline
Old 05-17-2011 | 03:47 AM
  #1304
Jstall7543's Avatar
Originally Posted by Chuck 21
Lots of guys asked for a Losi SCTE vs AE SC10
4x4 report from someone who races/owns both so here it is
I raced my SC10 4x4 on my home track that I've been racing my Losi SCTE
on so I could get a good test between the two.
#1 both run 2S 5600 60C,both RX8 ESC, both 4,5 550 motors the SCTE I
have a Novak 4.5 because it needs more torque then the AE. The AE I have
a Tekin 4.5 for a smoother power delivery. Same servo in both 7955TG Hitec
over kill yes but built proof IMO.
#2 both trucks are using DE SCTE wheels which (fit perfect on both)
Losi set up is silver springs all 4 corners stock pistons 40WT front 30WT
rear. 2.5mm sway bar rear,2.0mm sway bar front. Diffs 5,000 frt,5,000
center,3,000 rear
AE set up is Stock springs all 4 corners stock pistons 35WT front 30WT
rear. 2.5 mm sway bar rear 2.0mm sway bar front. Diffs 10,000 frt 5,000
rear. 4 wd full time 20/20 belt gears.
So now heres the driving.
#1 thing I noticed right away is the Losi jumped way better then the AE.
Now that is with silver springs on the Losi which jumped as bad as the AE
when it had stock springs. (got to be honest here) Give me springs for the
AE and I'm sure I can solve this on the AE also.
#2 The AE accelerates much harder the the Losi even with the higher
torque motor in the Losi. The AE will wheelie out of corners at will. This
looks cool but the Losi will put the power down flat at all times, the AE
you must think about how much throttle you give it out of corners.
#3 turn in, both are good here with the AE maybe having an edge but
the Losi is not running stock springs to get it there like the AE.
#4 Center corner speed has to go to the AE in all types of corners. It's
lighter with the same sway bars which gives a bit more speed in the center
IMO.
#5 exit corner speed. The AE has more on power tighter steering ability
then the Losi which can be good or a bad thing depending on how you
tend to drive. You can bind the AE up coming out with to much power
which will never happen on the Losi. You need more throttle control with
the AE to turn tight under power and not scrub speed.
#6 Braking. The Losi brakes rock solid straight and will stand on it's nose
hard (reverse wheelie) very locked in. The AE on the other hand skips the
belt at max braking and gets skidish IMO. Have to shoot straight here also.
The AE does not require as hard of braking as the Losi because it's lighter
then the Losi.So you won't probably have a problem braking even with the
Losi using less brake on the AE.
#7 stibility over bumps on power Both are awsome on power in bumps but
the Losi is a tick smoother.
#8 stibility over bumps off power the Losi is slightly better here but not a
bunch IMO
#9 stibility over bumps on brakes the Losi wins hands down (BUT) again
it is running silver springs not stock ones. I could do wonders with this
AE if I had different springs to choose from for it.
#10 slick track conditions Losi wins hands down stock or silver springs
the Losi is rock solid on slick. The AE is not bad but it does feel twitchy
some times.
#11 med grip track they both rock IMO they just rock different. AE is a little
twitchier then the Losi but a good twitchy if this makes sence to anyone.
IE: the AE is very responscive, the Losi you plan moves in advance is the
best way I can discribe this.
There was two new AE SC10 4x4's at the track with mine (no sway bars)
The local fast guys that dominate the class's they run all said my AE was
hands down the best out of the 3. They said mine was more planted and
solid looking all the way around the track. I respect what these guys have
to say about handling of cars/trucks, plus I beat the two other AE's by a
bunch and one is a much better driver then me. The Losi's I beat weekly
with my Losi SCTE I still beat by the same distance with my AE SC10 4x4
so IMO if I adapted my driving to the AE I was just as fast as I was with
my Losi but I have to drive them totally different to go that fast.
Bottom line IMO: Their both great trucks and will win their share of races.
I think driving style will dictate which truck you like to drive better. They
will both require tuning and tuning parts to get the best out of them but
they will both be the best on any giving days in the hands of drivers that
their driving style suits a givin truck.
I like them both, time will tell what I like better for my driving style. For
now I'll race them both and keep working on them til I feel I''m getting
the most out of them.
Nice job by both Losi & AE IMO... Thank you both of you"
Great review, thanks for taking the time.
Jstall7543 is offline
Old 05-17-2011 | 03:57 AM
  #1305
Jstall7543's Avatar
Synthol...
Your arms are tiny bro. Lol! your on the verge of a blow out! That's bigger than my leg!
