SC10 4x4 Thread
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
The sc10 4X4 steering is real fast and twitchy and the the 1258tg made it even worse. I have since switched to the 1256tg and have found that it calmed the steering down considerably. It made the truck more drivable. Now I have added the ACKbar by Mantisworx/RCShox. The tuning options now are great. I put the 1258 in my sc10 2wd which could use more steering speed. All works out.
What pinion would you suggest for the sc10 4x4 running the stock 32 pitch spur gear with a 5700kV motor?
For someone that's just starting out is 30 wt for all four shocks and 10,000 for both diffs good?
I just shimmed my rear diff using these: http://www.amainhobbies.com/product_...-ball-bearings.
They work perfectly except that you must remove the stock shim otherwise the diff will bind. By themselves the remove almost all of the wobbliness of the out-drives.
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
MERRY CHRISTMAS TO ALL MY SC10 4X4 BROS! MAY YOU ALL HAVE A KICK ASS RACE SEASON FOR 2012!!
![Rotating Tire](https://www.rctech.net/forum/classic_images/smilies/tire.gif)
Pinning the top shaft has been tried by quite a few people, and what it does is tie the two slipper plates back together. It provides the rear with two slipper plates it needs for acceleration, but now the front is tied to the rear, and can't spin at a slower speed when it needs to, like when it turns a corner.
So my track is hard packed clay with dust/sand on top. I'm thinking I should go with a pinned top shaft and lock the clicker down.
But don't you have the front clicker to help the front end? Doesn't the clicker act like a one-way and allow the front wheels to spin faster during off-power turns?
Yep that is how how pretty much everyone runs it including the Pro Drivers.
Lots of really good tuning tips here on this thread. Just do a search in this thread.
Also MantisWorks has great aftermarket products that enhance this truck.
good luck and enjoy.
I'm getting the new center diff which eliminates slipper pads all together.
![Cool](https://www.rctech.net/forum/classic_images/smilies/cool.gif)
BTW it's 80 degrees here today, not exactly Xmas weather.
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
Center diff? Can you post a link on the info if possible.
Switching to saddle packs. So deciding on which saddles is the hard part ![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
I attached 2 links to 2 different packs. Did anyone use either one of these lipo's?
http://www.hobbyking.com/hobbyking/s...ddle_Pack.html
http://www.hobbypartz.com/98p-25c-4800-2s3p-saddle.html
Is this all I need to convert to saddles?
ASC9775 - Team Associated Factory Team Lipo Battery Tray (B44.1)
ASC9706 - Team Associated Battery Post (B44)
ASC9786 - Team Associated Carbon Battery Strap (B44)
ASC6292 - Team Associated 4-40 x 3/8" Flat Head Screw (6)
ASC89229 - Team Associated Blue Countersunk Washer (10)
And by looking at the saddle pack thread most people are running the packs "inline" instead of side to side in the chassis? Is there a difference between the 2 in performance?
medium sized hardpacked outside clay track, medium traction. no big jumps very fast and technical with lots of sharp 180 turns
Chad , the inline changes direction left to right more responsively or quicker...
