Like Tree5Likes
SC10 4x4 Thread
Old 11-28-2011 | 09:34 AM
  #11551
I have my first 4x4 sc10 kit coming at the end of this week and im wondering what are suggested for hop-ups? sugestions for extra parts that usually break or have a weakness? and as well which ones would just be best to switch to aluminum? any help would be great thx.
J-RO is offline
Old 11-28-2011 | 09:57 AM
  #11552
Grouchman's Avatar
Originally Posted by rickybobbyxxx
Does anybody know if 44.1 saddle pack setup will work in the exoteck chassis??? Kinda looks like it would
I will find out tonight, my chassis is scheduled to be delivered today and I use the B44 saddle pack setup.
Grouchman is offline
Old 11-28-2011 | 10:17 AM
  #11553
CraigMBA's Avatar
No. Exoteck has their own proprietary mounting system, and it's drilled for that, or so I hear.
CraigMBA is offline
Old 11-28-2011 | 10:50 AM
  #11554
MantisWorx's Avatar
start reading! its on here numerous times
MantisWorx is offline
Old 11-28-2011 | 11:06 AM
  #11555
Mizchief's Avatar
I've yet to actually "break" anything on my truck, and I use a BMX track as my main practice track.
Long thread and you should stop being a noob and read it all, blah, blah blah, but it def helps to have some reference to search by.
Look into the slipper setup/issue, pin mod, arm warping, brace / new exotech chassis to prevent belt slipping on hard landings and hard breaking (been a problem for some but not me)
I haven't heard much about people upgrading to Al for hub carriers and stuff like that, those pieces seem stiff and durable.
Mizchief is offline
Old 11-28-2011 | 11:14 AM
  #11556
Thanks guys, of coarse they would have there own system for saddle packs, this shits getting old, im gonna have the most expensive short coarse truck on earth by the time we get this thing figured out lol
rickybobbyxxx is offline
Old 11-28-2011 | 11:38 AM
  #11557
Resqnu's Avatar
Originally Posted by Resqnu
I currently run a Novak HV 5.5 550 motor and mmp esc. I purchased the sc10 4x4 complete and came with this setup. I am happy with it so far, but don't know if a different motor is preferred. Ive only had the sc10 4x4 for a few weeks. I've been trying to keep up with this thread for all the great info and must say you guys rock!. I run a 1/10 scale indoor high traction track in the winter and a 1/8 scale outdoor track good traction, not blown out, in the warmer months. My question is what is the pros/cons of the 550 vs 540? Not trying to start a motor size war, just would like to hear comparisons from personal experiences. I also have a Novak ballistic 17.5 540 motor with a 13.5 & 10.5 stator. Would this motor be enough power with another sized stator?
Anybody?
Resqnu is offline
Old 11-28-2011 | 11:59 AM
  #11558
Artikbot's Avatar
Anybody?
A good 4pole 540 will be faster, cooler, lighter and more efficient than a 2pole 550.
If you were referring to 2pole 540s, then the main difference is smoothness. A 2pole 540 on a SCT is extremely smooth. But you'll want to go with a 5.5T X12 Octa and the biggest rotor available.
Artikbot is offline
Old 11-28-2011 | 12:21 PM
  #11559
Chad Smith's Avatar
What is everyone using to balance the truck? I know that some people where using 4 scale's under each wheel but dont remember what scales they where using.
Chad Smith is offline
Old 11-28-2011 | 12:34 PM
  #11560
Yep, it is for their own set up... I emailed to ask and they said it is not for the 44.1 mounts. Would be nice to hear from someone with b44.1 mounts if they are even close to lining up though.
Sofa King is offline
Old 11-28-2011 | 12:36 PM
  #11561
Vegatron75's Avatar
Anybody running the V2 holeshots? ON indoor hardpacked?
I've ran barcodes and rebars so far. Which have worked well, I think the barcodes work better than the rebars.
I run a small pin Panter tire, switch I think, on my E 1/8. The buggy is a treat to drive and is real predictable.
Just wondering if that'll translate to the truck. I'm not real jazzed about the proline foams though.....
Most all the 4x4 1/10 buggy guys run holeshots at the track. Everyone else runs some kind of barcode/suburb/wishbone deal...
Vegatron75 is offline
Old 11-28-2011 | 12:51 PM
  #11562
fastrc64's Avatar
i have been using the panther rattlers clay tires they work great
fastrc64 is offline
Old 11-28-2011 | 01:27 PM
  #11563
Oso Negro's Avatar
Smile
Originally Posted by symmetricon
OK OK, I messed up. Sorry to everybody who put the ackbar on per instructions on rcshox.com. I messed up after Marcus explicity told me to put them on a certain way. Somedays I am just retarded
The ACKbar needs to be put on the opposite way show. Also, snug the screws that hold the ACKbar down, and then back of 1/2 a turn. There is no need to overtight them! For quick dissasembly and re assembly, you can take the left side screw out, then you can rotate the righthand bellcrank until the screw is exposed. Rotate the ackbar so that the horns are facing forward. Put the righthand bellcrank and ackbar together then the left. Quick tip, to keep the aluminum spacers from folling out during assembly, put a dab of black grease on the outside of the spacer, then put it into the bottomside of the ackbar underneath the bearing.
Sorry Marcus and anyone else I screwed up
I had knee surgery, and was on vicodin... thats my excuse!
Good thing I've been to busy to install it since i got it. I would have been soooooooo confused!
Oso Negro is offline
Old 11-28-2011 | 01:36 PM
  #11564
slashracer111's Avatar
Ran my SC10 4x4 this weekend for the first time.
Only had a VXL motor, and a Sidewinder SCT esc. No power=Terrible finish
I was running against a sponsored driver, and one partially sponsored driver. Both running Losi's. Little club race. I got second though.
This thing REALLY needs some better electronics. My RX8 esc and SC4x 4.5 are supposed to be a birthday present. Seems that cannot get here any quicker.
I found the stock setup, with different shock oil and the clicker locked, wasn't all that bad. I didn't have enough power to really tell though.
I did notice the slipper... uh, sucked. Pinned slipper shaft and Garodiscs ordered.
slashracer111 is offline
Old 11-28-2011 | 02:37 PM
  #11565
BlueGlowBoy's Avatar
Originally Posted by Edumakated
this car feels more precise. It also took a minute to get used to it being deathly quiet. Out of the box, the Losi is pretty much dialed in but this car seems like it has more potential with the right setup.
The biggest issue for me is that it seemed to traction roll a lot.
Glad you seem to like it.... It's still my favorite, even with the teething pains of a new design. Honestly amazed at how well it has taken the abuse. Diffs and Slipper are my only real concerns, and I'm trying out a few of the suggestions that have been on here. (Garodiscs and different shims in the diff)
For your traction rolling, try putting 3mm of washers under both front and rear inner camber ball-studs. (I'm using part number 31286) Lowering the roll centre like that was the single most noticeable improvement to my truck in the early days. The truck was smoother in and out of corners and traction rolling was ALMOST a thing of the past. Just keep a few 10mm ball studs handy...this mod does make it slightly easier to bend one on a hard side impact.
BlueGlowBoy is offline
