Like Tree5Likes
SC10 4x4 Thread
Old 09-07-2011 | 07:32 PM
  #7321
ilanstylz's Avatar
Originally Posted by Manatarms25
Cool Thanks guys, I do plan on sticking with 540 motors so maybe I will try 48 pitch 1st. Since I have all the pinions already.
I have a couple different motor options to try Hopefully I do not have to take the 550 plunge, most tracks here I will run on are indoor and a tighter layout.
Do you guys carry extra belts with you at the track ? I will order up a clicker assembly and maybe the basics.
Sup Manta, I'm more familiar with my sc10 4x4 then 2wd (which by the way is working perfect now thanks)......... I've had my sc10 for awhile now and the original belt is holding up great, I did buy a spare just incase but as long as you break it in properly and set the tensioners correctly you should be fine........ Also I have a few 32P that will fit on a 540 or 3mm shaft motor in different sizes. If you want them you can have them just pm me your address and I'll ship them out asap........
ilanstylz is offline
Old 09-07-2011 | 08:07 PM
  #7322
B4TravSC10's Avatar
Got my new Hazard wheels from JC today. I can't wait to get them out on the track. I need to do a little body trim on the front. Back wheel sits right at fender now instead of being tucked inside.
B4TravSC10 is offline
Old 09-07-2011 | 08:56 PM
  #7323
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Been reading the thread for the last couple nights Great Front page BTW
I just picked up a used sc10 4x4 and will be installing a new Xerun 2.1 120a with either a 5.5 (540) tekin or a 1410 castle motor.
Would you guys recommend 32 pitch for indoor clay or is the 48 pitch ok ? With the 1410 at least
Also what spares are common to keep in your pit box.. I got to get a Amain order coming
Thanks everyone
Front bumper, front arms, front hub carriers/knuckles, CVA rebuild kit, slipper hardware (thrust bearing, spring, nut and a couple washers) and springs. That's all ThunderbirdJunkie keeps in his box. He's never had to rip into it at the track, though. The truck is solid.
14/62 32p to start with on the 1410's gearing, go from there. If it runs cool, gear up. if it runs hot, gear down.
T-BirdJunkie is offline
Old 09-07-2011 | 09:04 PM
  #7324
Aoh
Originally Posted by ITS ME DAVID
Then your gear mesh wasn't correct I'm usig the 3800 cc sct and 21/93 48p and have about 60 laps maybe more and my clutch and spur are in great shape I check then after every race or practice day.
20 years in this hobby, im pretty sure i can set my mesh.
Aoh is offline
Old 09-07-2011 | 09:09 PM
  #7325
CristianTabush's Avatar
Originally Posted by Sq0nk
In reviewing the chassis setup posts here I started to wonder how temperature comes into play when it comes to shock oil. Here in Phoenix it's pretty common to run in 100+ (many nights over 110). I'm wondering if anyone has experience with the heat and what kind of weights they run.
For example would an 80 degree setup of 35/30 f/r need something like 40/35 or even higher for 100+ temps? Obviously an overly simplified scenario in this case.
Perhaps temps do not have much of an impact on the oil...I really don't know.
Yes, temperature does affect the oil, and also the materials the truck is made out of. When it's hot, the shocks expand as do the pistons and the holes to a degree. Running 2 1/2 oil weight difference is a good way to adjust every 20-25 degrees of ambient temperature change.
CristianTabush is offline
Old 09-07-2011 | 09:11 PM
  #7326
ITS ME DAVID's Avatar
Then something is a problem then maybe slipper to tight and too much shock which is causing the stripped spur I mean I'm good after 60+ laps but I'm not a heavy driver.
ITS ME DAVID is offline
Old 09-07-2011 | 09:57 PM
  #7327
BLbound's Avatar
It could happen to anyone. I ran the 48p gear with my 5.5 & had no problem...just needed more torque so I went back to my 4.5 550 & 32p gears. Bs stuff can happen to any of us...I've got 22 years in the hobby...wow I don't want to know how much money I've put into this hobby!
BLbound is offline
Old 09-07-2011 | 11:34 PM
  #7328
Cameron Kellogg's Avatar
I don't have any issues with 48 pitch gears.
Cameron Kellogg is offline
Old 09-08-2011 | 03:43 AM
  #7329
Farmer_John's Avatar
Problems?
Other than scuffing and or replacing slipper pads and tightening the clicker, taking care of this truck is a no brainer.
The only parts that have actually broken was a front CVA and that was catastrophic. Even then, I just rebuilt it.
Set it up right the first time. Do the maintenance, make adjustments as needed. Tuesday night, the difference between not having or having rear traction was a 1 degree change in rear camber.
No problems.
Farmer_John is offline
Old 09-08-2011 | 09:45 AM
  #7330
Well, I've got two major mechnical issues with the truck-
1. Leaky diff. box- I've built at least 3 sets (brand new boxes) all leaks. Green slime on the seal didn't help much. Should I put two seals?
2. Belt popping off on the front- Have tried all the tension setttings, middle-middle seems to work better. But once I popped that 1st time (Almost like an twisted angle) its been poppin'...
GuiltyByAssoc is offline
Old 09-08-2011 | 10:36 AM
  #7331
1Fastpede's Avatar
1: try using LESS oil in the diff.
2: Take brake out. example: I run 35% brake.
1Fastpede is offline
Old 09-08-2011 | 10:45 AM
  #7332
try planing the diffs off take some 1600 grit sand paper and run the diff faces around in s circular motion I do that on all my diff cups helps a good bit
zixxer is offline
Old 09-08-2011 | 10:47 AM
  #7333
MILLER!'s Avatar
Originally Posted by 1Fastpede
I think alot of trucks would be loose with that motor!
my packs are down the middle and im adding weight on the back of the packs. which would be the front of your packs. 1.5oz to be exact.
Our track has really low traction, even when wet, I put the overdrive pulley on the front, and it made all the difference, truck was pulling 1/8 times, I have a video uploading right now, will post it when its done. That new 4pole motor is unreal, very smooth, and good on battery, no problem going 10 mins, came off at 140 degrees, speed controller was 124, even with under tray on it.
MILLER! is offline
Old 09-08-2011 | 10:58 AM
  #7334
1. Cool, I'll give that a shot!
2. I'm at 85% so less could be the answer, but now I don't even use the brakes just let it coast after the front straight let the drag brake do the work.
I think the jumps are causing the poppin'... too much chassis flex.
Old 09-08-2011 | 11:17 AM
  #7335
MantisWorx's Avatar
my front belt twisted yesterday after an awkward landing off of some big doubles so a chassis brace is needed for sure.
MantisWorx is offline
