Like Tree5Likes
SC10 4x4 Thread
Old 09-06-2011 | 07:12 PM
  #7291
smokinu's Avatar
Originally Posted by ITS ME DAVID
What tires are you using ?
hot bodies pink megabites with proline molded foams.
tires worked on my hyper very well. even worked awesome on a 2wd sc.
smokinu is offline
Old 09-06-2011 | 07:19 PM
  #7292
symmetricon's Avatar
Originally Posted by smokinu
lol i run mine locked down and just a smidge backed off. have not had a problem with it clicking yet.
Has anyone tried running the Rear in Underdrive instead of the front in Overdrive.
Im still fighting a setup for loose clay with med/high bite. wet to dry during the day.
i didnt like the underdrive in the rear or overdrive in the front. have you tried the saddle pack setup? since i did this the rear end seems more planted, after balancing and dding weight.
symmetricon is offline
Old 09-06-2011 | 07:20 PM
  #7293
smokinu's Avatar
i have 6.5oz of weight added to my truck. the next setup is a saddle pack config.
i didnt like the over drive in the front. so i never tried underdrive.
im running a losi for my next big race anyways.
smokinu is offline
Old 09-06-2011 | 08:33 PM
  #7294
Botwoon's Avatar
Mantis, did you test the Garodiscs with vented or normal hubs?
Botwoon is offline
Old 09-06-2011 | 09:03 PM
  #7295
ITS ME DAVID's Avatar
I run the aka rebars in super soft rear and soft in front and in clay I grip like a awd should lol
ITS ME DAVID is offline
Old 09-06-2011 | 11:52 PM
  #7296
Aoh
what does your f/r and cross weights look like?
Aoh is offline
Old 09-07-2011 | 01:50 AM
  #7297
MILLER!'s Avatar
here's what I got going on, where are you guys adding weight to balance the truck out? ran a couple laps and it was alittle loose, but nothing I couldnt fix with some setup changes.
MILLER! is offline
Old 09-07-2011 | 02:33 AM
  #7298
smokinu's Avatar
I wraped the front servo with 4oz of weight in 1\2 oz blocks.. then i put two oz under the motor up againts the rx box then 2.5oz on the gear cover side. next plan is to do a saddle pack config
smokinu is offline
Old 09-07-2011 | 05:02 AM
  #7299
I didnt write down the weight but i can remember approximate weights.
FL600
FR600
RL720
RR720
The odd thing about this is that when attached strig to the bottom of the chassi via the screws that attch the bumper to the chassi, I was heavy on the motor side, so I added more weight to the rear off motor side.
I added
FL21grams
FR35grams
RL20grams
RR64grams
A total fo 4.375oz
Old 09-07-2011 | 06:37 AM
  #7300
bronc4now's Avatar
Originally Posted by turbowop
w00t! New hawtness. The red brand matches my springs better than the old green can anyways...
Are those ofna big bore shocks ? Do they fit right on or did you need to mod something?
bronc4now is offline
Old 09-07-2011 | 01:07 PM
  #7301
Is anybody using the Castle Creations Mamba Max Pro/1415 combo? If so what are your thoughts? How do you have it geared?
Chris Gierse is offline
Old 09-07-2011 | 01:16 PM
  #7302
BlueGlowBoy's Avatar
I know someone running that in a different chassis, and even with the smallest gearing she's got, it's overkill for even a large 8th scale track.
1410 with a real ESC is more than enough.
Now...if you're bashing, gear that thing to the moon! It will take it and you'll hit highway speeds!
BlueGlowBoy is offline
Old 09-07-2011 | 01:51 PM
  #7303
1Fastpede's Avatar
I think alot of trucks would be loose with that motor!
my packs are down the middle and im adding weight on the back of the packs. which would be the front of your packs. 1.5oz to be exact.
1Fastpede is offline
Old 09-07-2011 | 01:58 PM
  #7304
Kind of what I thought. Really waiting to see what Viper comes up with in their new Copperhead line. Thanks for the info.
Old 09-07-2011 | 04:16 PM
  #7305
Been reading the thread for the last couple nights Great Front page BTW
I just picked up a used sc10 4x4 and will be installing a new Xerun 2.1 120a with either a 5.5 (540) tekin or a 1410 castle motor.
Would you guys recommend 32 pitch for indoor clay or is the 48 pitch ok ? With the 1410 at least
Also what spares are common to keep in your pit box.. I got to get a Amain order coming
Thanks everyone
Manatarms25 is offline
