SC10 4x4 Thread
#7173
I run mine in the middle on both tensioners. My belt should be broke by now and I still haven't tightened it up any more.
To tight will cause binding,don't want that, and too much brake will make the belt skip on the front pulley, not a huge deal. Turn you brake epa down enough to lessen the skipping.
#7174
Who runs the LRP X12L 5.5 in the sc10 4x4.
what do you think of it ( honestly )
temps? gearing ?
I cant control the heat in this thing. all my timing is set to zero, runnig a 13T pinion on 62 spur. and this baby heats up to much to fast
I do like the smoothnes.. but Im having second thoughts.
No heat problems with my speedpassion 550 sized silverarrow 6.5
No heat problems with my 3800kv castle 4-pole
runnig midzised hardpacked clay track outdoors..
temps? gearing ?
#7175
So I found out tonight that I have to check my slipper nut after every race. I run on a high bite clay track & was running a variation of cavs setup, 27.5 with yellow springs in the rear. We have a quad where most of us triple-single & in my 1st qualifier I noticed I couldn't clear them like I had been doing in practice. Then I checked my slipper & sure enough the nut had backed off to being flush. I normally run it tightened down 2 threads with a clutch basket. Moral of the story is check your car after every race instead of leaving it in your pit & jaw jacking with the buddies! I qualified 6th
but finished 2nd
but finished 2nd
.-Jorge
#7176
#7178
Im having a hard time keeping temps under 195F that is 8 minutes driving with 77F outside temps
you use the stock timing from the motor itself? ( standard insert with 4 markings )
and I drive fairly consistant, dont even push that hard
#7179
I was going to say gear up also... Murky you are into the high RPM's to long with the 5.5 with that small pinion. Try bumping it up a few teeth, run it for 3 minutes then temp it. If it's still to hot, you most likely demagnetized the rotor and the motor will never run to its potential. And with 10 degrees of timing you are actually at 40 degrees total timing.
#7180
I will try to gear up when I hit the tracks later this week.
pffff when symmetricon told what his temps where I thought I must be doing something wrong, but it couldnt be my driving.
but I do know how to drive my truck dough, bringing home some prizes once in a while. even on national level.
Ill keep you guys posted
edit: just dont understand why EA suggest a 13T in the manual of the sc10 4x4
#7181
Different motors have different power bands. Start on the low end of the gearing chart for a given motor and work up, being easier on the motor. They could always tell you to gear it to the moon and cook a motor.
#7182
I drove out to san antonio this weekend to race and test some new goodiies and the air tems were 100+deg. Your belts arent too tight, your front and rear diff cases doent bind? and yes stock motor timing.
I hope you figure it out, because this motor has impressed me.
#7183
no binding , belt pretty loose, running clicker. diffs fine.
I keep my truck always in top shape. after every race I clean and poslish the whole truck and check everything.
gearing up like saladfork says sounds right theoreticly. maybe Im to long in the high rmp's
#7184
I recently switched to a saddle pack style set up, and it felt very good on a track that I have never driven on. Im running IP 5600 50c batteries. I got them from Pro-Match. I recently had some problems with some stick pack style batteries I bought from them and swapped them out for the IP packs (pan style). The batteries are on sale for 25$ a pack!!!!! I ran them tis weekend and they were awesome, 3000mah after 10 min, they still felt very punchy. Here is picks of my ride.
I also ran Rcshox slipper pads, they worked great, were very adjustable in terms of how much slipping happens. They felt ery consistent and did not fade when runing the slipper on the loose side. Here is some more pics of how te pads looked after running.
as you can see there is no deformation or abnormal wear on the slipper hubs or slipper pads. I was very impressed.
I have to say that it is great testing out Rcshox parts.
#7185
Pat, that was a great race, man we traded spots like 5 times. Did the heavier fluid help you settle down more on the jump in front of the drivers stand. I was running yellow's all the way around but felt a little springy on that landing running 30wt in the front and 25wt in the rear. I am going to try 35 front and 27.5 rear next. Are you running the high torque pads with the basket? I had to switch to those to keep it consistent.
-Jorge
-Jorge
5Likes
