SC10 4x4 Thread
#6721
I need to recheck tonight!!
#6722
The AE trucks are some of the narrowest of the trucks with the exception of the Durango. The new Jconcepts wheel makes the AE trucks wider and at ROAR legal limit. Wider might and should improve stability. Its just something new to try that all the team guys are running right now it is just hard to find the new Jconcepts wheels to try it though.
I know the Kyosho truck with the AKA wheels needs to almost be hammered into the tech box.
#6724
They are wider indeed.
Thinking about getting a set with some Proline Trenchers once my rear stockers wear (not anytime soon, this things are DAMN hard!! I wonder if AE used wood to dmold them
By the way, just serving as info. The Savox 1251 is plenty enough for the truck, just mounted mine.
Problem with it is, it is too short to fit onto the stock servo mount blocks.
Solution? Get a spare lower cover, cut a small piece of the side and re-route the wire to exit from the cover and not from the side. Seal the box with watever you prefer, I used a rubber o-ring and some electrical tape cut in proper width in order not to completely cover the heatsink.
Ah, and the wire is pleeenty long to reach the box.
Why did I mod my 1251 instead of getting a 1257? Because I got it for real cheap, around 25% cheaper than retail.
)By the way, just serving as info. The Savox 1251 is plenty enough for the truck, just mounted mine.
#6726
If I could find a set to run I would like to test run them to see if its noticeable better. Lower CG is something we all have been chatting about so it might help. For right now I will test the DE xxxt-sc wheel and see if I can tell a difference.
#6729
#6730
DE does not make a special wheel yet. I was just looking at the wheels that are made now to see if one is already that off-set. Turns out this is something special that Jconcepts made for Mayfield,BK, and the AE/Jconcepts team for the SC10. Now that they won again we all need to have this wheel off-set right?
i think im going to throw a 4mm washer or two on top of each hex to test the wider stance. not the best solution, but i do have serrated nuts....
#6731
#6732
#6734
The ones for the rear xxxt-sc (2w truck) are somewhat wider that the stock sc10 4w wheels. The only thing you need to be careful about is that the rim is thicker also so the axle might not be long enough to get in the nylock part of the wheel nut. I don't physically have the wheels yet; the info I have is what I have been told by Dave at DE Racing so I am going to do some testing when I get a couple of sets to play with.
#6735
Been using the Blitz offset wheels with Barcodes since I got my SC10 4x4.
I stole them from my Blitz and has stayed with the SC10 4x4 ever since - lol.
Definately wider than the stock AE wheels.
I ended up using a blitz body and modifed the body post holes.
When using the AE body on the Blitz wheels, the wheels stick out about 4-5 mm on each side.
But with the Blitz body, its tucked in.
I tried my AE wheels but prefer the Blitz offset.
I may use the AE body and trim the wheel wells and make it fit. Looks kind of funny though with the wheels so wide - lol.
5Likes
